I finally got a Guardline driveway alarm for my long driveway. They work well and are the favorites in rural settings. Basically a well housed and adjustable PiR and a nice base station. Reading the manual before purchase I found that it indeed has a NO/NC relay output. I can BLYNK that. I set up next to the alarm and added two bridge units for remote parts of the house like downstairs and out back. i also, get Blynki Notifications. Bridge has been very reliable. Best part, I get alarms when I am not at home. Additional Virtuals are to silence the unit.
// D1 mini pro Driveway Alarm Base
#include <ESP8266mDNS.h> // ***********For OTA w/ ESP8266
#include <WiFiUdp.h> // **********For OTA
#include <ArduinoOTA.h> // ************For OTA
char auth[] = "XXXXXXXXXXXXXbb90e47adb36661480d31a738";
// 2nd auth code XXXXXXXXX66b9e9af21be7a8d8f4
char ssid[] = "OnHub";
char pass[] = "XXXXX";
char IP[] = "blynk.equinemediaworld.com"; // The
WidgetBridge bridge1(V7);
int x, x2, x3, x4, x5, x6;
int val = 0;
BLYNK_CONNECTED() {
bridge1.setAuthToken("XXXXXXXXXXXe9af21be7a8d8f4");
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V4);
Blynk.syncVirtual(V5);
BLYNK_WRITE(V0) {
x = param.asInt();
BLYNK_WRITE(V1) {
x2 = param.asInt();
BLYNK_WRITE(V2) {
x3 = param.asInt();
BLYNK_WRITE(V3) {
x4 = param.asInt();
BLYNK_WRITE(V4) {
x5 = param.asInt();
if (x5) {
tone1();
BLYNK_WRITE(V5) {
x6 = param.asInt();
if (x6) {
tone2();
void tone1( ) {
Serial.print("TONE 1");
for (int z = 0; z < 7; z++) {
tone(15, 440, 200);
delay(500);
tone(15, 800, 200);
delay(500);
bridge1.virtualWrite(V8, 1);
delay(500);
bridge1.virtualWrite(V8, 0);
void tone2( ) {
Serial.print("TONE 2");
for (int z = 0; z < 8; z++) {
tone(15, 900, 200);
delay(100);
tone(15, 600, 200);
delay(100);
bridge1.virtualWrite(V9, 1);
delay(500);
bridge1.virtualWrite(V9, 0);
void PIRval() {
val = 0;
val = digitalRead(13); // Driveway
Serial.print("PIRval 1 = ");
Serial.println(val);
if ( x2 == 1 && val == HIGH) {
digitalWrite(16, HIGH);
tone1( );
else {
digitalWrite(16, LOW);
if (val == HIGH && x == 1) {
Blynk.notify("Driveway Alarm");
val = 0;
val = digitalRead(12); // Front Door
Serial.print("PIRval 2 = ");
if ( x4 == 1 && val == HIGH) {
digitalWrite(4, HIGH);
tone2( );
else {
digitalWrite(4, LOW);
if (val == HIGH && x3 == 1) {
Blynk.notify("Front Door Alarm");
// Serial.begin(9600);
Blynk.begin(auth, ssid, pass, IP, 8080);
pinMode(12, INPUT); // PIR 1
pinMode(13, INPUT); // PIR 2
pinMode(16, OUTPUT); //LED
pinMode(5, OUTPUT); //LED
pinMode(4, OUTPUT); //LED
pinMode(15, OUTPUT); //Tone Alarm
for (int y = 0; y < 6; y++) {
delay(100);
delay(100);
delay(500);
delay(500);
digitalWrite(5, HIGH);
delay(500);
digitalWrite(5, LOW);
delay(500);
delay(500);
delay(500);
timer.setInterval(300L, PIRval);
ArduinoOTA.setHostname("d1 mini Pro Driveway Alarm Base"); // For OTA - Use your own device identifying name
ArduinoOTA.begin(); // For OTA
ArduinoOTA.handle(); //************* For OTA
Bridge 1
// D1 Mini Driveway Alarm
//+++++++++ remote ++++++++++++++++
char auth[] = "XXXXXXXXXXXXXX6b9e9af21be7a8d8f4";
char pass[] = "XXXXXXXXX";
int x1, x2;
BLYNK_CONNECTED() {
Blynk.syncVirtual(V8);
Blynk.syncVirtual(V9);
tone(15, 440, 500);
BLYNK_WRITE(V8) {
x1 = param.asInt();
if (x1) {
tone1();
BLYNK_WRITE(V9) {
x2 = param.asInt();
if (x2) {
tone2();
void tone1( ) {
tone(15, 440, 200);
delay(500);
tone(15, 800, 200);
delay(500);
void tone2( ) {
for (int z = 0; z < 12; z++) {
tone(15, 900, 200);
delay(100);
tone(15, 600, 200);
delay(100);
digitalWrite(0, LOW);
delay(500);
digitalWrite(0, HIGH);
pinMode(0, OUTPUT); //LED
ArduinoOTA.setHostname("D1 Mini Pro Drive Alarm Remote 2"); // For OTA - Use your own device identifying name
tone1();
