- Arduino UNO + ESP8266
- Using android
- Blynk Server
- Analog Sensor
Hello. i need help with my problems using Arduino + ESP8266.
first thing is i have 2 arduino, Arduino A i used for my project with esp and blynk, and Arduino B used for trials the sensor analog ( let’s say it’s pH sensor )
when Arduino B connect to my sensor in analog pin, the result was good enough (i see the results on serial monitor) and it match with the datasheet of this sensor.
but the problem starts with Arduino A for my project. i try to connect my sensor to my project, and displayed the results on my phone. the data doesn’t match with the first trial in Arduino B.
i don’t even move my sensor to another soil. but the results is different.
Arduino B have ADC range from 0-80, but arduino A 0-300.
i try to compare my sketch from Arduino A and B, and i think there isn’t any problem with that.
would you tell me how to fix it ? i know maybe this topic should be send in arduino forum. but my thanks if you guys help me…
// Set your ESP-01 baud rate to 9600 with this command AT+UART_DEF=9600,8,1,0,0
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
#define DHTPIN 8
#define DHTTYPE DHT22
#define pHsensor A0
DHT dht(DHTPIN, DHTTYPE);
const int LEDPIN1 = 4;
const int LEDPIN2 = 5;
const int LEDPIN3 = 6;
const int LEDPIN4 = 7;
const int LEDPIN5 = 9;
int Potensio;
int Potensio1;
int sensorPHValue = 0;
float sensorPH =0.0;
BLYNK_WRITE(V1)
// Send Data As Status 1/0 from Blynk App to Arduino Digital Pin
int pinValue = param.asInt();
if (param.asInt()){
digitalWrite(LEDPIN1, HIGH);
digitalWrite(LEDPIN1, LOW);
void PotensioSENSOR()
// Read Analog Data from Sensor, then Send to Blynk App
Potensio = analogRead(A1);
Potensio = map(Potensio, 0, 1023, 100, 0);
Blynk.virtualWrite(4, Potensio);
void ledempat();
void ledlima();
void ledempat(){
if (Potensio <= 50){
digitalWrite(LEDPIN2, HIGH);
digitalWrite(LEDPIN2, LOW);
void ledlima(){
if ( Potensio <=20){
digitalWrite( LEDPIN4, HIGH);
else if ( Potensio >=80){
digitalWrite( LEDPIN4, LOW);
void Potensio1SENSOR()
// Read Analog Data from Sensor1, then Send to Blynk App
Potensio1 = analogRead(A2);
Potensio1 = map(Potensio1, 0, 1023, 100, 0);
Blynk.virtualWrite(6, Potensio1);
void ledenam();
void ledtujuh();
void ledenam(){
if (Potensio1 <=50){
digitalWrite(LEDPIN3, HIGH);
digitalWrite(LEDPIN3, LOW);
void ledtujuh(){
if (Potensio1 <=20){
digitalWrite(LEDPIN5, HIGH);
else if ( Potensio1 >=80){
digitalWrite(LEDPIN5, LOW);
void pHchecking(){
sensorPHValue = analogRead(pHsensor);
sensorPH = (-0.0693*sensorPHValue)+7.3855;
Blynk.virtualWrite(7, sensorPH);
Serial.println(sensorPH);
void myTimerEvent()
void sendSensor()
// Send Sensor Data from DHT22 to Blynk App
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(" Failed to read from DHT sensor!");
return;
Blynk.virtualWrite(V3, h);
Blynk.virtualWrite(V2, t);
void Sent_Serial()
String content = " ";
char character;
while(Serial.available()){
character = Serial.read();
content.concat(character);
Serial.println();
// Set Pin Mode in Arduino
pinMode(LEDPIN1, OUTPUT);
pinMode(LEDPIN2, OUTPUT);
pinMode(LEDPIN3, OUTPUT);
pinMode(LEDPIN4, OUTPUT);
pinMode(LEDPIN5, OUTPUT);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
dht.begin();
timer.setInterval(50L, sendSensor);
timer.setInterval(50L, PotensioSENSOR);
timer.setInterval(50L, Potensio1SENSOR);
timer.setInterval(100L, pHchecking);
timer.setInterval(50L, ledempat);
timer.setInterval(50L, ledlima);
timer.setInterval(50L, ledenam);
timer.setInterval(50L, ledtujuh);
timer.setInterval(500, Sent_Serial);
