Blynk adafruit VL53L0X on Wemos D1 Mini Pro
It should be something like below:
void myTimerEvent(){  distance= measure.RangeMilliMeter;  Blynk.virtualWrite(V6, distance);}
(Changing V5 to V6 for example)
Check Arduino examples once you install the Adafruit Library, I don’t have such sensor to play with…
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  Serial.println("Adafruit VL53L0X test");
  if (!lox.begin()) {
    Serial.println(F("Failed to boot VL53L0X"));
    while(1);
  // power
  Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
  VL53L0X_RangingMeasurementData_t measure;
  Serial.print("Reading a measurement... ");
  lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
  if (measure.RangeStatus != 4) {  // phase failures have incorrect data
    Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
    Serial.println(" out of range ");
  delay(100);
Regards
