where to find this similar project code ?
I can not find any blynk project with this sensor
Easy…
You can look at my post
@xjn2k6, I see your code for esp32 not wemos D1,
and the sensor is GYVL53LOX not adafruit VL53lox,
wondering which code to be change…
I hope I can do this, I’m not a programmer for sure.
@psoro, yes it’s easy without Blynk.
this is for temp sensor which is analog (A0) sketch
void myTimerEvent(){ sensorData = analogRead(A0); Blynk.virtualWrite(V5, sensorData);}
but what about i2c input ?
It should be something like below:
void myTimerEvent(){ distance= measure.RangeMilliMeter; Blynk.virtualWrite(V6, distance);}
(Changing V5 to V6 for example)
Check Arduino examples once you install the Adafruit Library, I don’t have such sensor to play with…
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
// wait until serial port opens for native USB devices
while (! Serial) {
delay(1);
Serial.println("Adafruit VL53L0X test");
if (!lox.begin()) {
Serial.println(F("Failed to boot VL53L0X"));
while(1);
// power
Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
VL53L0X_RangingMeasurementData_t measure;
Serial.print("Reading a measurement... ");
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
if (measure.RangeStatus != 4) { // phase failures have incorrect data
Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
Serial.println(" out of range ");
delay(100);
Regards
I’ve been doing this sketch but no luck
I got counter 1, 2, 3, 4… and so on on my blynk widget
must be sending the wrong data to Virtual pin …
Can you post your code?
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void myTimerEvent()
//distance= measure.RangeMilliMeter;
Blynk.virtualWrite(V6, millis() / 1000);
while (! Serial) {
delay(1);
if (!lox.begin()) {
while(1);
// power
// delay(1000);
it’s a mess sketch you ever seen
It is indeed…
First of all, clean your loop… remove all stuff related your sensor from there and create a new event to put those lines and read the sensor data.
I’m not at home now to post an example.
Can you please test this code?
Remember I don’t have such sensor…
int distance =0;
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void myTimerEvent()
void mydistanceEvent)()
distance=measure.RangeMilliMeter;
Blynk.virtualWrite(V7, distance);
Blynk.virtualWrite(V7, "out of range");
lox.begin()
timer.setInterval(100L, mydistanceEvent);
psoro,
it works , much appreciate your help
regards
