I connected 4 pcs PCF8574 to control 32 relays. In principle it works too. But there is a problem after rebooting the ESP32. After successful connection with the Blynkserver I start the Blynkapp and press Button 1. Now all relays connected to the first PCF8574 switch on. I then have to turn on all 8 relays in the app and then switch off again, then it works correctly.
What have I already tried? I’ve set all the pins high (which you do not really need since they’re usually high already). But do not change the behavior.
What else could I do to make it work properly? Have read a lot, but can not get on. Please help. thanks
And please excuse my English is not my native language
Blynk runs on a local server on my Raspberry Pi 3+
ESP32 Dev v3 and power supply 220 volts to 5 volts 2 amps
PS: Have now again Blynk.virtualWrite HIGH rausgenommen. Same behavior. after reboot of the ESP32 are all relays off, but I press V1 or V9 in the app, all 8 or 16 relays have gone on. At the 2 channel relay this effect does not occur, here it goes as it should. Is only so with the two 16 channel relay modules.
#include <PCF8574.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#define SDA_PIN 21 //GPIO21 on ESP32
#define SCL_PIN 22 //GPIO22 on ESP32
PCF8574 addr1 (0x20); // PCF8574 device (addr1) 1 ACHTUNG! Adresse 0x20 einstellen A0>0,A1>0,A2>0 Port-Bereich P0-P8 (addr Namen kann man frei wählen)
PCF8574 addr2 (0x21); // PCF8574 device (addr2) 2 ACHTUNG! Adresse 0x21 einstellen A0>1,A1>0,A2>0 Port-Bereich P0-P8
PCF8574 addr3 (0x22); // PCF8574 device (addr3) 3 ACHTUNG! Adresse 0x22 einstellen A0>0,A1>1,A2>0 Port-Bereich P0-P8
PCF8574 addr4 (0x23); // PCF8574 device (addr4) 4 ACHTUNG! Adresse 0x23 einstellen A0>1,A1>1,A2>0 Port-Bereich P0-P8
//PCF8574 addr5 (0x24); // PCF8574 device (addr5) 5 ACHTUNG! Adresse 0x24 einstellen A0>0,A1>0,A2>1 Port-Bereich P0-P8
//PCF8574 addr6 (0x25); // PCF8574 device (addr6) 6 ACHTUNG! Adresse 0x25 einstellen A0>1,A1>0,A2>1 Port-Bereich P0-P8
//PCF8574 addr7 (0x26); // PCF8574 device (addr7) 7 ACHTUNG! Adresse 0x26 einstellen A0>0,A1>1,A2>1 Port-Bereich P0-P8
//PCF8574 addr8 (0x27); // PCF8574 device (addr8) 8 ACHTUNG! Adresse 0x27 einstellen A0>1,A1>1,A2>1 Port-Bereich P0-P8
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
int pinValue1;
BLYNK_WRITE(V1){
int pinValue1 = param.asInt();
addr1.digitalWrite(0, pinValue1);
int pinValue2;
BLYNK_WRITE(V2){
int pinValue2 = param.asInt();
addr1.digitalWrite(1, pinValue2);
int pinValue3;
BLYNK_WRITE(V3){
int pinValue3 = param.asInt();
addr1.digitalWrite(2, pinValue3);
int pinValue4;
BLYNK_WRITE(V4){
int pinValue4 = param.asInt();
addr1.digitalWrite(3, pinValue4);
int pinValue5;
BLYNK_WRITE(V5){
int pinValue5 = param.asInt();
addr1.digitalWrite(4, pinValue5);
int pinValue6;
BLYNK_WRITE(V6){
int pinValue6 = param.asInt();
addr1.digitalWrite(5, pinValue6);
int pinValue7;
BLYNK_WRITE(V7){
int pinValue7 = param.asInt();
addr1.digitalWrite(6, pinValue7);
int pinValue8;
BLYNK_WRITE(V8){
int pinValue8 = param.asInt();
addr1.digitalWrite(7, pinValue8);
int pinValue9;
BLYNK_WRITE(V9){
int pinValue9 = param.asInt();
addr2.digitalWrite(0, pinValue9);
int pinValue10;
BLYNK_WRITE(V10){
int pinValue10 = param.asInt();
addr2.digitalWrite(1, pinValue10);
int pinValue11;
BLYNK_WRITE(V11){
int pinValue11 = param.asInt();
addr2.digitalWrite(2, pinValue11);
int pinValue12;
BLYNK_WRITE(V12){
int pinValue12 = param.asInt();
addr2.digitalWrite(3, pinValue12);
int pinValue13;
BLYNK_WRITE(V13){
int pinValue13 = param.asInt();
addr2.digitalWrite(4, pinValue13);
int pinValue14;
BLYNK_WRITE(V14){
int pinValue14 = param.asInt();
addr2.digitalWrite(5, pinValue14);
int pinValue15;
BLYNK_WRITE(V15){
int pinValue15 = param.asInt();
addr2.digitalWrite(6, pinValue15);
int pinValue16;
BLYNK_WRITE(V16){
int pinValue16 = param.asInt();
addr2.digitalWrite(7, pinValue16);
int pinValue17;
BLYNK_WRITE(V17){
int pinValue17 = param.asInt();
addr3.digitalWrite(0, pinValue17);
int pinValue18;
BLYNK_WRITE(V18){
int pinValue18 = param.asInt();
addr3.digitalWrite(1, pinValue18);
int pinValue19;
BLYNK_WRITE(V19){
int pinValue19 = param.asInt();
addr3.digitalWrite(2, pinValue19);
int pinValue20;
BLYNK_WRITE(V20){
int pinValue20 = param.asInt();
addr3.digitalWrite(3, pinValue20);
int pinValue21;
BLYNK_WRITE(V21){
int pinValue21 = param.asInt();
addr3.digitalWrite(4, pinValue21);
int pinValue22;
BLYNK_WRITE(V22){
int pinValue22 = param.asInt();
addr3.digitalWrite(5, pinValue22);
int pinValue23;
BLYNK_WRITE(V23){
int pinValue23 = param.asInt();
addr3.digitalWrite(6, pinValue23);
int pinValue24;
BLYNK_WRITE(V24){
int pinValue24 = param.asInt();
addr3.digitalWrite(7, pinValue24);
int pinValue25;
BLYNK_WRITE(V25){
int pinValue25 = param.asInt();
addr4.digitalWrite(0, pinValue25);
int pinValue26;
BLYNK_WRITE(V26){
int pinValue26 = param.asInt();
addr4.digitalWrite(1, pinValue26);
int pinValue27;
BLYNK_WRITE(V27){
int pinValue27 = param.asInt();
addr4.digitalWrite(2, pinValue27);
int pinValue28;
BLYNK_WRITE(V28){
int pinValue28 = param.asInt();
addr4.digitalWrite(3, pinValue28);
int pinValue29;
BLYNK_WRITE(V29){
int pinValue29 = param.asInt();
addr4.digitalWrite(4, pinValue29);
int pinValue30;
BLYNK_WRITE(V30){
int pinValue30 = param.asInt();
addr4.digitalWrite(5, pinValue30);
int pinValue31;
BLYNK_WRITE(V31){
int pinValue31 = param.asInt();
addr4.digitalWrite(6, pinValue31);
int pinValue32;
BLYNK_WRITE(V32){
int pinValue32 = param.asInt();
addr4.digitalWrite(7, pinValue32);
Blynk.begin(auth, ssid, pass, IPAddress(192, 168, 0, 19), 8080);
addr1.begin();
addr2.begin();
addr3.begin();
addr4.begin();
addr1.pinMode (0, OUTPUT);
addr1.pinMode (1, OUTPUT);
addr1.pinMode (2, OUTPUT);
addr1.pinMode (3, OUTPUT);
addr1.pinMode (4, OUTPUT);
addr1.pinMode (5, OUTPUT);
addr1.pinMode (6, OUTPUT);
addr1.pinMode (7, OUTPUT);
addr2.pinMode (0, OUTPUT);
addr2.pinMode (1, OUTPUT);
addr2.pinMode (2, OUTPUT);
addr2.pinMode (3, OUTPUT);
addr2.pinMode (4, OUTPUT);
addr2.pinMode (5, OUTPUT);
addr2.pinMode (6, OUTPUT);
addr2.pinMode (7, OUTPUT);
addr3.pinMode (0, OUTPUT);
addr3.pinMode (1, OUTPUT);
addr3.pinMode (2, OUTPUT);
addr3.pinMode (3, OUTPUT);
addr3.pinMode (4, OUTPUT);
addr3.pinMode (5, OUTPUT);
addr3.pinMode (6, OUTPUT);
addr3.pinMode (7, OUTPUT);
addr4.pinMode (0, OUTPUT);
addr4.pinMode (1, OUTPUT);
addr4.pinMode (2, OUTPUT);
addr4.pinMode (3, OUTPUT);
addr4.pinMode (4, OUTPUT);
addr4.pinMode (5, OUTPUT);
addr4.pinMode (6, OUTPUT);
addr4.pinMode (7, OUTPUT);
Blynk.virtualWrite(V1, HIGH);
Blynk.virtualWrite(V2, HIGH);
Blynk.virtualWrite(V3, HIGH);
Blynk.virtualWrite(V4, HIGH);
Blynk.virtualWrite(V5, HIGH);
Blynk.virtualWrite(V6, HIGH);
Blynk.virtualWrite(V7, HIGH);
Blynk.virtualWrite(V8, HIGH);
Blynk.virtualWrite(V9, HIGH);
Blynk.virtualWrite(V10, HIGH);
Blynk.virtualWrite(V11, HIGH);
Blynk.virtualWrite(V12, HIGH);
Blynk.virtualWrite(V13, HIGH);
Blynk.virtualWrite(V14, HIGH);
Blynk.virtualWrite(V15, HIGH);
Blynk.virtualWrite(V16, HIGH);
Blynk.virtualWrite(V17, HIGH);
Blynk.virtualWrite(V18, HIGH);
Blynk.virtualWrite(V19, HIGH);
Blynk.virtualWrite(V20, HIGH);
Blynk.virtualWrite(V21, HIGH);
Blynk.virtualWrite(V22, HIGH);
Blynk.virtualWrite(V23, HIGH);
Blynk.virtualWrite(V24, HIGH);
Blynk.virtualWrite(V25, HIGH);
Blynk.virtualWrite(V26, HIGH);
Blynk.virtualWrite(V27, HIGH);
Blynk.virtualWrite(V28, HIGH);
Blynk.virtualWrite(V29, HIGH);
Blynk.virtualWrite(V30, HIGH);
Blynk.virtualWrite(V31, HIGH);
Blynk.virtualWrite(V32, HIGH);
// timer.run();
