Click Create (the event will appear in the Events tab list)
Repeat the previous step for the second event with the name Error.
Click Save to save and apply the changes made (select Update active device this time)
By default, we will have 2 events online and offline.
But I want to add other events for Virtual Pins to track usage history.
So, can you explain to me, when we use Blynk.virtualWrite(V,value); What is Blynk 2.0 to record Events on the system with COde?
Thank you
I don’t really understand what it is that you are trying to achieve.
You seem to be saying that you want battery readings to be displayed in the events timeline, as well as in your Superchart? If so, then this isn’t how events are designed to be used.
I am very sorry that my question was confusing to you.
As you know, Events Online and Offline use Event Code which is online and offline, it is similar to Event notify to replace Blynk.email and blynk.notify.
That said, when using Blynk.virtualWrite(V,value), there will probably also be an Event code for this function.
I need it, in order to be able to function Event to view the Timeline for the Virtual pin.
The Chart function was there and I used it, but it didn’t work for me.
The Get Device History Data function is a bit complicated.
The Automation function can be used to send emails and notifications.
Simply put, I want to see in the Timeline section.
I think, there will be a code like online and offline, to write data to the server. I hope we figure it out.
I have used and understood it, but this function is a bit inconvenient to use. If I can use the Event code for Virtual Pins, I can conveniently view the Notifications section on the App.
I hope the publisher will pay attention to this need to install accordingly.
I understand that I can create a new Event, with the event code maybe “Blynkwrite” and put it in the device like this:
My question is, can the event code “Blynkwrite” be a code you designed in the library with a different name and what is its name?
If so, similar to the online and offline event code, I would use the Event function without having to put the Blynk.logEvent code in the device’s firmware.
@nlqt2021 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
