Blynk 2.0 - Data Sent To Mobile Dashboard Different Font
Hi, is there a reason why data sent to the mobile dashboard (virtual pin) as type Integer or Double is a different font to other data sent as type String?
In the example below you can clearly see that the values for Threshold, Raw Reading and Vcc are a smaller font than the other data that was sent as String.
There is no way that I can see to change the font in this case.
Thoughts?
I’m not sure if this is possible on iOS because I’m not an IOS user, but we can adjust the font size in the Android version of the app.
Hi John,
IOS we can adjust the font for text or string data that appears in Labeled Value widget - but the received integer or double data doesn’t conform with any font change - always stays as that skinny font.
feels like a bug to me - fon’t was fine in Blynk legacy
billd
@Eugene one for you to look at?
