I want to convert my below code to blynk.
#include <MPU6050_tockn.h>
#include <Wire.h>
#include <EEPROM.h>
MPU6050 mpu6050(Wire);
// EEPROM address to store reference angles
int eeAddressX = 0;
int eeAddressY = sizeof(float);
int eeAddressZ = 2 * sizeof(float);
// Variables to store reference angles
float refAngleX = 0.0;
float refAngleY = 0.0;
float refAngleZ = 0.0;
Wire.begin();
mpu6050.begin();
mpu6050.calcGyroOffsets(true);
// Read reference angles from EEPROM
EEPROM.get(eeAddressX, refAngleX);
EEPROM.get(eeAddressY, refAngleY);
EEPROM.get(eeAddressZ, refAngleZ);
mpu6050.update();
Serial.print("angleX : ");
Serial.print(mpu6050.getAngleX() - refAngleX);
Serial.print("\tangleY : ");
Serial.print(mpu6050.getAngleY() - refAngleY);
Serial.print("\tangleZ : ");
Serial.println(mpu6050.getAngleZ() - refAngleZ);
// Check if reset button is pressed
if (digitalRead(D9) == LOW) {
delay(50); // Debounce delay
calibrateAngles(); // Reset reference angles to 0.0
void saveReferenceAngles() {
EEPROM.put(eeAddressX, refAngleX);
EEPROM.put(eeAddressY, refAngleY);
EEPROM.put(eeAddressZ, refAngleZ);
void calibrateAngles() {
const int readings = 100;
float sumX = 0.0;
float sumY = 0.0;
float sumZ = 0.0;
for (int i = 0; i < readings; i++) {
mpu6050.update();
sumX += mpu6050.getAngleX();
sumY += mpu6050.getAngleY();
sumZ += mpu6050.getAngleZ();
refAngleX = sumX / readings;
refAngleY = sumY / readings;
refAngleZ = sumZ / readings;
saveReferenceAngles();
- If I use edgenet, what should be the board configuration for XIAO esp32 C3
- If I simply use <BlynkSimpleEsp32.h>, then how should I reconfigure/connect the project in BLYNK 2.0?
- Since this sketch uses EEPROM, will it affect BLYNK functioning? i.e. in storage of wifi credentials etc?
Try one of the example sketches for ESP32 in the Sketch Builder, nut I’d recommend using the SSL ones rather than the one that use <BlynkSimpleEsp32.h>.
Once you have the board working then add-in your code to the example sketch. You’ll wnat to clean-up your void loop though…
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
If you use Edgent then you’ll need to be careful because Edgent also uses EEPROM. If you search the forum you’ll find a few posts about how to avoid overwriting the Edgent saved settings.
You will probably want to define your own board type in Settings.h if you use Edgent, or modify the Custom board type.
Is there any reason why you’re using the SEEED Studio board for this project?
I use them for a battery p[owered project that requires a small footprint board, but its not a board that I’d normally choose.
Thanks for the prompt response, SSL sketch worked. Does this sketch use EEPROM?
Without knowing which example you’ve used it’s difficult to say, but it should be very simple for you to work-out.
here’s my updated code:
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- ESP32 board
example.
/* Fill-in information from Blynk Device Info here */
//#define BLYNK_TEMPLATE_ID "TMPxxxxxx"
//#define BLYNK_TEMPLATE_NAME "Device"
//#define BLYNK_AUTH_TOKEN "YourAuthToken"
#define BLYNK_TEMPLATE_ID "TMPL6NXNsQ1YH"
#define BLYNK_TEMPLATE_NAME "CD"
#define BLYNK_AUTH_TOKEN "GTo8YrNbZk3xkHbZujzHUfIKWqrawYvx"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32_SSL.h>
#include <Wire.h>
#include <EEPROM.h>
char ssid[] = "vivo 1713";
char pass[] = "ablgaozra";
int btnpin = D9;
int eeAddressX = 0;
void cdi(){
mpu6050.update();
Blynk.virtualWrite(V1,mpu6050.getAngleZ() - refAngleX);
Blynk.virtualWrite(V2,mpu6050.getAngleZ() - refAngleY);
Blynk.virtualWrite(V3,mpu6050.getAngleZ() - refAngleZ);
if (digitalRead(btnpin) == LOW) {
Wire.begin();
mpu6050.begin();
timer.setInterval(500L, cdi);
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 443);
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8443);
float sumX = 0.0;
float sumY = 0.0;
float sumZ = 0.0;
mpu6050.update();
// to avoid delay() function!
So is your problem now solved?
yes, the data is visible on Blynk app but there’s a lag, I’ll try to figure it out.
Thanks again.
