I am using Arduino Uno to read data from the sensor and transfer the data to my esp8266 by using Rx and Tx pin, there is no problem with serial communication. But I got problems reading and sending data from Blynk 2.0 for the data stream. Plus, I’m newbie to Blynk. Thank you in advance.
#define BLYNK_TEMPLATE_ID "xxx"
#define BLYNK_TEMPLATE_NAME "xxx"
#define BLYNK_AUTH_TOKEN "xxx"
//arduino-nodemcu data transfer lib
#include<SoftwareSerial.h>
#include<ArduinoJson.h>
// wifi details
char ssid[] = "xxx";
char pass[] = "xxx";
//D2=Rx & D1=Tx
SoftwareSerial arduino(D2,D1);
bool RED_status = true;
bool GREEN_status = true;
bool PIR1_status = true;
bool PIR2_status = true;
BLYNK_WRITE(V1){
digitalWrite(RED_status, param.asInt());
void send_data() {
StaticJsonBuffer<1000> jsonBuffer;
JsonObject& data = jsonBuffer.parseObject(arduino);
if (data == JsonObject:: invalid ()){
Serial.println("Invalid JSON Object");
jsonBuffer.clear();
return;
Serial.println("JSON object received");
Serial.print("RED status: ");
bool RED_status= data["RED_status"];
Serial.print(RED_status);
Serial.print(" ,Motion status: ");
bool PIR1_status= data["PIR1_status"];
Serial.println(PIR1_status);
Serial.print("GREEN status: ");
bool GREEN_status= data["GREEN_status"];
Serial.print(GREEN_status);
bool PIR2_status= data["PIR2_status"];
Serial.println(PIR2_status);
Serial.print("Light status: ");
double sensorValue= data["Light_status"];
Serial.println(sensorValue);
Blynk.virtualWrite(V0, sensorValue);
Serial.println("----------------------------------------------");
// initialize Serial Port
arduino.begin(9600);
while(!Serial) continue;
Blynk.begin(auth,ssid,pass, "blynk.cloud",8080);
void loop(){
send_data();
