Hi! I would like to use tinyzero with Blynk 2.0. However, I am having trouble compiling the libraries. It seems that the there is a library that is conflicting with Blynk latest library (it can compile ok if I use an older verison of Blynk).
• Tinyzero with wifishield
• Blynk latest 1.1.0
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPLZxDIqJSt"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "lXEr_RwRJP4jn_wy7B_AF0_cIoZv2keN"
#define BLYNK_PRINT SerialUSB
#include <WiFi.h>
#include <BlynkSimpleWifi.h>
char ssid[] = "AndriodAP";
char pass[] = "gaco3897";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
SerialUSB.begin(115200);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
Error:
In file included from c:\users\aXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\char_traits.h:39:0,
from c:\users\aXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\string:40,
from c:\users\aXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\stdexcept:39,
from c:\users\aXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\array:39,
from c:\users\aXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\tuple:39,
from c:\users\aXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\functional:54,
from c:\Users\AXXXXX\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:39,
from c:\Users\AXXXXX\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:37,
from c:\Users\AXXXXX\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from c:\Users\AXXXXX\Documents\Arduino\libraries\Blynk\src/Adapters/BlynkWiFiCommon.h:24,
from c:\Users\AXXXXX\Documents\Arduino\libraries\Blynk\src/BlynkSimpleWifi.h:24,
from C:\Users\AXXXXX\Documents\Arduino\tinyzero_wifi\tinyzero_wifi.ino:19:
c:\users\AXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:243:56: error: macro “min” passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\AXXXXX\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:265:56: error: macro “max” passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
exit status 1
Compilation error: exit status 1
