Created a Blynk 2.0 Cloud account and preparing to move over all my projects. I did this for one project, create template added device, web dashboard and iOS app widgets setup. All working and data pumping in with my test rig. Next day I login to blynk.cloud and it looks like my account has been completed reset, all content missing. On my phone all the information and previously configured stuff is still there. Please advise,
This isn’t something to do with GEO DNS/load balancing is it and what server you content sits on?
Region: sgp1 on the PC browser interface and ny3.blynk.cloud on mobile app
This account for this forum is separate to the account that has the issue (this account is for legacy blynk).
Definitely logging in using correct email address, tried several different browsers, cleared cookies and all of that. Tried different computers also as well as trying when using a VPN into the US, still no go.
I had filled in all the Organization Information create data streams, templates. All of that is gone
Interestingly there is a template there now, how-ever it was the first one I created yesterday and it only has a single web widget added. I had created graphs and a few other displays.
I don’t understand that comment at all.
Are both the app’s “About” screen and the bottom right hand corner of the web console showing the same SGP1 region?
You’ve created an account on both the Singapore and New York servers.
From what you’ve said, the account that you want to keep is the one on the Singapore server.
If you are using the free (basic) account then things are simple.
Just delete the New York account from your web console (User Profile, three dots next to your name, Delete Account) then turn-off your VPN and log in to the web console again.
If you have problems resolving the Singapore server, or you need to use the VPN on your PC then try accessing your web console via…
https://sgp1.blynk.cloud/dashboard
If you have signed-up to a subscription on the New York server then things are more complicated, and you may need to cancel that subscription and re-subscribe on the Singapore account.
Morning Peter, thanks for the info, havent payed for a sub yet…
Looks like that has worked, the data I would like to retain actually is in NY3, as the mobile app is show my previously setup information.
Ive deleted by account, navigated to https://ny3.blynk.cloud/ and was able to login on my PC and my previously configured Org, templates, datastreams and devices are now visible.
I’m located in Australia, so assuming the correct server should be Singapore (given its proximity). How do I get my account moved as I would prefer not to have to specify https://ny3.blynk.cloud/ each time I want to login on any PC.
