I have a Arduino nano which is using the below bluetooth module to connect to my android phone.
I have setup a Blynk project to connect to the Arduino with bluetooth. Everything seems to connect fine and the bluetooth module’s “connect” LED lights up.
When I look at the serial monitor however, I get a message that repeats “login timeout”.
Also I have tried including some basic code just to activate the digital pin 13 on the Arduino but that doesn’t even light up. See below my code used to connect to the phone and Blynk app, its basically the standard example supplied by Blynk with my own pin values etc.
I cant get a button on the Blynk app to activate pins on my arduino and more worrying is the fact that I can’t even get pin D13 to light up from the arduino code.
Note sure whats happening here so any advise would be appreciated.
http://twitter.com/blynk_app
Warning: Bluetooth support is in beta!
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Nano board
example.
SoftwareSerial SwSerial(7, 8); // RX, TX
char auth[] = "8e9354f3c75148acb8eb2efb56e221c7";
SoftwareSerial SerialBLE(7, 8); // RX, TX
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
// to avoid delay() function!
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
