Hello, I’m trying the new connection bluetooh with HC-06 only got not success, aparenemente everything is normal connected however try a simple command to trigger a button but nothing works, anyone have any suggestions?
I am using a one arduino and bluetooth module HC-06.
char auth[] = "20185cadd1db4fe2b784880c6ea29965";
DebugSerial.begin(9600);
// 9600 is for HC-06. For HC-05 default speed is 38400
Blynk.begin(auth, Serial);
