I have a Bluefruit LE uart friend and Arduino Uno, and thought the app I can connect the module to my iPhone, however as soon as I start the program the module disconnects. Why is this happening?
Blynk app version?
Blynk library version?
Sketch?
Serial monitor output?
Connection diagram?
Blynk app version:2.26.8 (1)
Blynk library version: 1.0.1
Connection: vin - 5v, gnd - gnd, tx - rx, rx - tx
The serial monitor just says ‘waiting for connections’.
sketch:
SoftwareSerial DebugSerial(0, 1); // RX, TX
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char auth[] = "B_AlPndu8snMP7-KyIIeOpS-k450_0Oq";
DebugSerial.begin(9600); // Debug console
DebugSerial.println("Waiting for connections...");
Blynk.begin(Serial, auth);
You are using blynk legacy, you should use blynk library version 0.6.1 instead of 1.0.1
What do you see when you open the BLE widget in the Blynk app? Are your seeing the device and making the connection there?
@John93 I have installed blynk library 0.6.1 and installed 1.0.1 however the Bluetooth module still doesn’t connect. I have connected to it with another app so I know it works. Is there anything else?
Try pins (2, 3) instead of (0, 1)
@PeteKnight In the BLE widget I see the module and making the connection there, however it says can’t connect.
Have you tried this :
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example shows how to use Adafruit Bluefruit LE nRF8001 breakout
to connect your project to Blynk.
Note: This requires BLEPeripheral library
from http://librarymanager/all#BLEPeripheral
or https://github.com/sandeepmistry/arduino-BLEPeripheral
NOTE: BLE support is in beta!
#include <BlynkSimpleBLEPeripheral.h>
#include <BLEPeripheral.h>
// Define pins (varies per shield/board)
#define BLE_REQ 10
#define BLE_RDY 2
#define BLE_RST 9
// Create ble serial instance, see pinouts above
BLESerial SerialBLE(BLE_REQ, BLE_RDY, BLE_RST);
SerialBLE.setLocalName("Blynk");
SerialBLE.setDeviceName("Blynk");
SerialBLE.setAppearance(0x0080);
SerialBLE.begin();
Blynk.begin(SerialBLE, auth);
SerialBLE.poll();
if (SerialBLE) { // If BLE is connected...
Can you post screenshots of that, along with what your serial monitor shows at the same point in time.
This won’t work because I have the uart friend ble module, which connects through serial tx rx, and the sketch that you have suggested uses spi connection which uses REQ, RDY, RST. Thank you for the suggestion though.
Okay, can you show me your wiring diagram please ?
I guess you should read this :
