styled button provide issue when I have more than 4 blinking buttons.
Blynk.setProperty(Vx, “onBackColor”, color);
process freeze until I reset nodeMCU
so I have to forget this design
Now it’s solved !
int Step=0;
timer.setInterval(200, Blinkbutton);
void Blinkbutton() {
if (Step == 9) {
Step = 0;
Step++;
switch (Step) {
case 1:
if (BTN1 == true) {
if (F1 == 1) {
Blynk.setProperty(V1, "onBackColor", DARK_RED);
F1 = 0;
Blynk.setProperty(V1, "onBackColor", DARK_GREEN);
F1 = 1;
break;
case 2:
if (BTN2 == true) {
if (F2 == 1) {
Blynk.setProperty(V2, "onBackColor", DARK_RED);
F2 = 0;
Blynk.setProperty(V2, "onBackColor", DARK_GREEN);
F2 = 1;
break;
case 3:
if (BTN3 == true) {
if (F3 == 1) {
Blynk.setProperty(V3, "onBackColor", DARK_RED);
F3 = 0;
Blynk.setProperty(V3, "onBackColor", DARK_GREEN);
F3 = 1;
break;
case 4:
if (BTN4 == true) {
if (F4 == 1) {
Blynk.setProperty(V4, "onBackColor", DARK_RED);
F4 = 0;
Blynk.setProperty(V4, "onBackColor", DARK_GREEN);
F4 = 1;
break;
case 5:
if (BTN5 == true) {
if (F5 == 1) {
Blynk.setProperty(V5, "onBackColor", DARK_RED);
F5 = 0;
Blynk.setProperty(V5, "onBackColor", DARK_GREEN);
F5 = 1;
break;
case 6:
if (BTN6 == true) {
if (F6 == 1) {
Blynk.setProperty(V6, "onBackColor", DARK_RED);
F6 = 0;
Blynk.setProperty(6, "onBackColor", DARK_GREEN);
F6 = 1;
break;
case 7:
if (BTN7 == true) {
if (F7 == 1) {
Blynk.setProperty(V7, "onBackColor", DARK_RED);
F7 = 0;
Blynk.setProperty(V7, "onBackColor", DARK_GREEN);
F7 = 1;
break;
case 8:
if (BTN8 == true) {
if (F8 == 1) {
Blynk.setProperty(V8, "onBackColor", DARK_RED);
F8 = 0;
Blynk.setProperty(V8, "onBackColor", DARK_GREEN);
F8 = 1;
break;
Hehe… your issue wasn’t a Blynk problem… just “too much too fast” causing disconnection.
Interesting results… I will add this to my “weird things to do with Blynk” studies
yes Gunner,
it’s not realy a blynk issue.
but there’s no issue with virtual LEDs.
I tried with different timers.
1000, 2000 , 3000, same issue when there is more than 4 styled buttons.
I assume it’s due to short delay between each blynk instructions. so it’s not possible to blink more than 4 buttons at same time.
try it and forward me your experience.
