I’m trying to use the “simple beginner” example blueprint to blink the LED on a ESP32. The ESP32 works as I’ve run a timed blink sketch on it. When I open the .ino file normally in the Arduino IDE (v2.3.4) NINE tabs open and compiling takes forever but I eventually get a string of errors about WIFI.
If I open by “add file” as the tutorial says, (or paste code in new sketch) compiler can’t find BlynkEdgent.h.
I’ve installed 2 blynk libraries, deleted and reinstalled, and the files are in the same folder as .ino.
After several hours running in circles I gave up around mid-night. But I couldn’t sleep thinking about the problem!
In file included from C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\BlynkEdgent.h:8,
from C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\Edgent_Blynk_ESP32_LED.ino:18:
c:\BA\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h: In member function 'void BlynkWifi<Transport>::connectWiFi(const char*, const char*)':
c:\BA\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:67:9: error: 'WiFi' was not declared in this scope
67 | WiFi.mode(WIFI_STA);
c:\BA\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:67:19: error: 'WIFI_STA' was not declared in this scope
c:\BA\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:67:19: note: the macro 'WIFI_STA' had not yet been defined
In file included from C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\WiFi\src/WiFi.h:33,
from C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\OTA.h:2,
from C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\BlynkEdgent.h:45:
C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\WiFi\src/WiFiType.h:35: note: it was later defined here
35 | #define WIFI_STA WIFI_MODE_STA
c:\BA\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:73:33: error: 'WL_CONNECTED' was not declared in this scope; did you mean 'BLYNK_CONNECTED'?
73 | while (WiFi.status() != WL_CONNECTED) {
| BLYNK_CONNECTED
In file included from C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\BlynkEdgent.h:43:
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'String getWiFiMacAddress()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:147:10: error: 'WiFi' was not declared in this scope
147 | return WiFi.macAddress();
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'String getWiFiApBSSID()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:152:10: error: 'WiFi' was not declared in this scope
152 | return WiFi.softAPmacAddress();
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'String getWiFiNetworkSSID()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:157:10: error: 'WiFi' was not declared in this scope
157 | return WiFi.SSID();
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'String getWiFiNetworkBSSID()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:162:10: error: 'WiFi' was not declared in this scope
162 | return WiFi.BSSIDstr();
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'void enterConfigMode()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:167:3: error: 'WiFi' was not declared in this scope
167 | WiFi.mode(WIFI_OFF);
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:167:13: error: 'WIFI_OFF' was not declared in this scope
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:167:13: note: the macro 'WIFI_OFF' had not yet been defined
C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\WiFi\src/WiFiType.h:34: note: it was later defined here
34 | #define WIFI_OFF WIFI_MODE_NULL
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:169:13: error: 'WIFI_AP' was not declared in this scope
169 | WiFi.mode(WIFI_AP);
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:169:13: note: the macro 'WIFI_AP' had not yet been defined
C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\WiFi\src/WiFiType.h:36: note: it was later defined here
36 | #define WIFI_AP WIFI_MODE_AP
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In lambda function:
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:332:21: error: 'WiFi' is not captured
332 | int wifi_nets = WiFi.scanNetworks(true, true);
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:330:33: note: the lambda has no capture-default
330 | server.on("/wifi_scan.json", []() {
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:167:3: note: '<typeprefixerror>WiFi' declared here
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:338:19: error: 'WiFi' is not captured
338 | wifi_nets = WiFi.scanComplete();
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:350:15: error: 'WiFi' is not captured
350 | if (WiFi.RSSI(indices[j]) > WiFi.RSSI(indices[i])) {
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:350:39: error: 'WiFi' is not captured
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:367:11: error: 'WiFi' is not captured
367 | WiFi.SSID(id).c_str(),
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:368:11: error: 'WiFi' is not captured
368 | WiFi.BSSIDstr(id).c_str(),
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:369:11: error: 'WiFi' is not captured
369 | WiFi.RSSI(id),
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:370:24: error: 'WiFi' is not captured
370 | wifiSecToStr(WiFi.encryptionType(id)),
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:371:11: error: 'WiFi' is not captured
371 | WiFi.channel(id)
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:377:7: error: 'WiFi' is not captured
377 | WiFi.scanDelete();
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'void enterConnectNet()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:417:3: error: 'WiFi' was not declared in this scope
417 | WiFi.enableSTA(false);
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:440:54: error: 'WL_CONNECTED' was not declared in this scope; did you mean 'BLYNK_CONNECTED'?
440 | while ((timeoutMs > millis()) && (WiFi.status() != WL_CONNECTED))
| BLYNK_CONNECTED
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:451:24: error: 'WL_CONNECTED' was not declared in this scope; did you mean 'BLYNK_CONNECTED'?
451 | if (WiFi.status() == WL_CONNECTED) {
| BLYNK_CONNECTED
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'void enterConnectCloud()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:475:10: error: 'WiFi' was not declared in this scope
475 | (WiFi.status() == WL_CONNECTED) &&
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:475:27: error: 'WL_CONNECTED' was not declared in this scope; did you mean 'BLYNK_CONNECTED'?
| BLYNK_CONNECTED
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:495:14: error: 'WiFi' was not declared in this scope
495 | } else if (WiFi.status() != WL_CONNECTED) {
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:495:31: error: 'WL_CONNECTED' was not declared in this scope; did you mean 'BLYNK_CONNECTED'?
| BLYNK_CONNECTED
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h: In function 'void enterSwitchToSTA()':
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:520:3: error: 'WiFi' was not declared in this scope
520 | WiFi.mode(WIFI_OFF);
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:520:13: error: 'WIFI_OFF' was not declared in this scope
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:520:13: note: the macro 'WIFI_OFF' had not yet been defined
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:522:13: error: 'WIFI_STA' was not declared in this scope
522 | WiFi.mode(WIFI_STA);
C:\BA\Arduino\Sketches\Edgent_Blynk_ESP32_LED\ConfigMode.h:522:13: note: the macro 'WIFI_STA' had not yet been defined
exit status 1
Compilation error: 'WiFi' was not declared in this scope
I can also repeat the code but it is direct from the zip file (w or w/o authentication info). Bah, why not. Here it is.
// *** MAIN SETTINGS ***
// Replace this block with correct template settings.
// You can find it for every template here:
// https://blynk.cloud/dashboard/templates
#define BLYNK_TEMPLATE_ID "TMPL2AmdMBOLi"
#define BLYNK_TEMPLATE_NAME "LED ESP32"
//#define BLYNK_DEBUG
#define APP_DEBUG
#include "BlynkEdgent.h"
#define LED_PIN 2 // Use pin 2 for LED (change it, if your board uses another pin)
// V0 is a datastream used to transfer and store LED switch state.
// Evey time you use the LED switch in the app, this function
// will listen and update the state on device
BLYNK_WRITE(V0)
// Local variable `value` stores the incoming LED switch state (1 or 0)
// Based on this value, the physical LED on the board will be on or off:
int value = param.asInt();
if (value == 1) {
digitalWrite(LED_PIN, HIGH);
Serial.print("value =");
Serial.println(value);
digitalWrite(LED_PIN, LOW);
Serial.print("value = ");
pinMode(LED_PIN, OUTPUT);
// Debug console. Make sure you have the same baud rate selected in your serial monitor
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
If you’d have taken a few minutes to search this forum for the compilation error message “‘WiFi’ was not declared in this scope” you would have found this…
I think you for your help. I did spend, not only minutes, but hours researching in numerous locations (including here) for the answers to various aspects of the problems. 50 plus error messages about 9 tabs *.h tabs that opened by themselves were somewhat overwhelming. In fact, I searched here immediately before posting. Perhaps I got hung up on the “File not found” error message on the Edgent.h.
Mr. Knight, you seem knowledgeable and I appreciate your willingness to share that knowledge. I understand it must be frustrating when us new idiots can’t even figure out the easy stuff or want you to do our work for us. But even in the little time I’ve spent here (less than a few minutes, I guess) I saw your name repeatedly and almost every time you come across as . . . gruff. Sometimes even rude and it doesn’t help. There seems to be a link in inverse proportion between the intelligence gene and the courtesy gene on forums. Buck evolution!.
No problem, I’m happy to refrain from gruffly pointing you in the direction of solutions in future. Just add a little note to future posts that my input is not required.
