Dear All
Have a nice day
Please advice best OTA library that can support Node MCU
Thanks in advanced
PA3040
Dear All
Have a nice day
Thanks in advanced
PA3040
In my opinion the blynk edgent is the best one to use with blynk.
You mean blynk edgent is supporting OTA programing right?
I checked it but I didn’t see it ,please advice
Check this out
https://docs.blynk.io/en/getting-started/updating-devices-firmwares-ota#1.-prepare-your-device-for-ota-updates
Is there any direct upload please
What do you mean exactly ?
I mean without importing firmware to another browser and just click Arduino IDE upload button
No, I don’t think this is possible
If you want to do the upload directly from the Arduino IDE then the ArduinoOTA system is the one to use.
Drawbacks of the ArduinoOTA are:
The Blynk.Air OTA system is better, because devices don’t have to be on the same network, and doesn’t use Bonjour.
Drawbacks of Blynk.Air (in my opinion) are:
BLYNK_FIRMWARE_VERSION
to be incrementedThe BLYNK_FIRMWARE_VERSION
issue isn’t really a problem, it’s just that it’s easy to forget to incitement the number then you do the “Export compiled binary” process then “Show sketch folder” and drag the .ino file over to Blynk.Air and do the upload - which then fails.
It would be nice if you were warned that the current firmware version is “x” and the new firmware version is also “x”, do you wish to proceed?
Also, dragging the exported binary over to Blynk.Air isn’t really an issue either, if you follow the steps I described above. It’s not as smooth as choosing the network upload port in the IDE, but you soon get used to it.
