hello, If you can help me… I am basic English. How connect blynk? but cannot connect. What’s wrong code?
Thank you
here copy code:
#include <Arduino.h>
#include "HX711.h"
#include <EEPROM.h>
#include "src/settings.cpp"
const char wifiSSID[] = "******";
const char wifiPassword[] = "******";
const char blynkAuth[] = "*********************************"; // for each weight
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = D1;
const int LOADCELL_SCK_PIN = D2;
// about 5 minutes 293e6
// about 20 minutes 1193e6
// const double DEEP_SLEEP_TIME = 293e6;
// Deep sleep interval in seconds
int deep_sleep_interval = 285;
Settings settings;
WiFiClient client;
HX711 scale;
// Attach Blynk virtual serial terminal
WidgetTerminal terminal(V3);
// deep sleep interval in seconds
BLYNK_WRITE(V8)
if (param.asInt())
deep_sleep_interval = param.asInt();
Serial.println("Deep sleep interval was set to: " + String(deep_sleep_interval));
Blynk.virtualWrite(V7, String(deep_sleep_interval));
// Synchronize settings from Blynk server with device when internet is connected
BLYNK_CONNECTED()
Blynk.syncAll();
// device is enabled
bool isEnabled = true;
// Turn on/off
BLYNK_WRITE(V0)
isEnabled = param.asInt();
// Terminal input
BLYNK_WRITE(V3)
String valueFromTerminal = param.asStr();
if (String("clear") == valueFromTerminal)
terminal.clear();
terminal.println("CLEARED");
terminal.flush();
if (String("restart") == valueFromTerminal || String("reset") == valueFromTerminal)
terminal.clear();
terminal.println("RESTART");
terminal.flush();
delay(500);
ESP.restart();
else if (valueFromTerminal != "\n" || valueFromTerminal != "\r" || valueFromTerminal != "")
terminal.println(String("unknown command: ") + valueFromTerminal);
terminal.flush();
Serial.println("Initializing the scale");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
delay(300);
scale.power_up();
EEPROM.begin(512);
bool secondChange = false;
if (!scale.is_ready())
secondChange = true;
scale.power_down();
delay(300);
scale.power_up();
if (scale.is_ready())
// Sencor SBS 113L
scale.set_scale(settings.scale);
// formula A. B. C
// float average = scale.get_units(10);
// if (average < 0)
// average = average * -1;
// float value = average + settings.offset;
// formula E, F
float value = scale.get_units(10) + settings.offset;
if (value < 0)
value = value * -1;
Serial.println("average:\t" + String(value) + " kg");
int connAttempts = 0;
Serial.println("\r\nTry connecting to: " + String(wifiSSID));
WiFi.begin(wifiSSID, wifiPassword);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
if (connAttempts > 30)
Serial.println("Error - couldn't connect to WIFI");
break;
connAttempts++;
Blynk.config(blynkAuth, "*******.my****cloud.com", 17080);
Blynk.connect(2000);
if (Blynk.connected())
Serial.println("WiFI connected OK");
Serial.println("No WIFI !");
// wait for blynk sync
Blynk.virtualWrite(V2, WiFi.RSSI());
Blynk.virtualWrite(V5, isEnabled ? (secondChange ? "OK 2 pokusy" : "OK") : "Váha je vypnuta.");
if (isEnabled)
Serial.println("ENABLED");
Blynk.virtualWrite(V1, value);
float previousValue = 0.00f;
EEPROM.get(0, previousValue);
EEPROM.put(0, value);
EEPROM.commit();
float difference = value - previousValue;
Blynk.virtualWrite(V6, difference);
Serial.println("DISABLED");
Serial.println("Sent OK");
Serial.println("HX711 doesn't work");
Blynk.begin(blynkAuth, wifiSSID, wifiPassword, "*******.my****cloud.com", 17080);
Serial.println("Connect blynk");
int rssi = WiFi.RSSI();
Blynk.virtualWrite(V2, rssi);
if (secondChange)
Blynk.virtualWrite(V5, "HX711 nefunguje. 2. pokus");
Blynk.virtualWrite(V5, "HX711 nefunguje.");
Serial.println("Blynk send");
scale.power_down();
delay(300);
if (WiFi.isConnected())
Blynk.disconnect();
WiFi.disconnect(true);
Serial.println("Disconnected OK");
Serial.println("Already disconnected");
EEPROM.end();
Serial.println("Go to sleep for " + String(deep_sleep_interval) + " seconds.");
ESP.deepSleep(deep_sleep_interval * 1000000);
other: "src/settings.cpp" copy here:
// Project settings
struct Settings
const double scale = 22500.0; // for each weight
const double offset = 0.9; // for each weight
I am copy code from website: GitHub - vitzaoral/beehive_weight: Bee hive weight monitoring
here serial monitor: no connect no wifi..
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.0 on ESP8266
[7559] Connecting to nas012975.myqnapcloud.com:17080
No WIFI !
ENABLED
[11187] Disconnected
Disconnected OK
Go to sleep for 285 seconds.
