Bad auth token
Here’s the sketch i’m using to drive servo with NdeMCU. keep getting
[852420] connecting to blynk-cloud.com:80
[888553] invalid auth token
#include <Servo.h>
Servo servo;
#define BLYNK_DEVICE_NAME           "SERVO CONTROL"
#define BLYNK_AUTH_TOKEN            "TymRnAFT8KjICgkWjNxRtWo2YRUXruXV"
#define BLYNK_TEMPLATE_ID "TMPLd9pPWCBm"
char ssid[] = "Axxxxxxx";
char pass[] = "vxxxxxx1";
  servo.attach(15); // NodeMCU D8 pin
BLYNK_WRITE(V1)
   servo.write(param.asInt());
BLYNK_WRITE(V2)
  servo.write(0);
BLYNK_WRITE(V3)
  servo.write(90);
```cpp
PLEASE HELP!
Must be at the top of your sketch, the first lines.
It’s always a good idea to quote the error message exactly (Invalid auth token, not Bad auth token) and to search the forum for that problem before creating a new post.
If you’d have done that you would have found this:
