Project is saved on server. So you don’t need to worry.
For example if you buy a new phone all you have to do is install blynk app and login using your blynk account and you will find everything is same as the old phone.
… hello,
thanks for the first answers.
for shure ?
I never see this as Option after the install i make in the past.
I only see , create new project.
So I can test it if i take a second mobile phone , and install Blynk with my acoount data and see what happend .
So it must be on the second phone a complete clone.
In theorie then i can make with my acoount serveral Phone and Tablets by using one acoount, right ?
It’s not a clone, cloning in Blynk is something else.
You can access your Blynk account t from multiple mobile devices at the same time, you just log in to Blynk with the same credentials and you have the same data being displayed simultaneously. If you change the status of a switch widget then the same widget will change on the other mobile device.
