Automation setup <condition - action> button problem
I’ve created many projects using Blynk and I enjoy using the Automation function. However, suddenly I’m unable to control the <condition & action> setup in the Datastreams. Could you help me understand what the problem might be?
Hello @haewon. Thanks for report. Yes, this issue reproduced for me. We will fix this bug in next deploy.
Thank you and Could you let me know when this bug can be fixed?
Hello @haewon I think we’ll deploy fix this week or next week at the latest.
It works well now. Thank you very much!!
I’d also double-check that the widget and the automation are both using the same datastream. I’ve been caught out by that before, and everything looked correct until I noticed they were pointing to different virtual pins. It’s an easy thing to miss.
