Hey! just curious. Is it possible to display the schedule I made on Blynk’s Automation to display on a physical LCD ? If can, how to do it?
The schedule from your automations isn’t available as data that can be passed from the Blynk server to your device, so no - it’s not possible.
If you used the Time Input widget then yes, it would be possible to display the schedule data and remaining time until the next on/off event, but that would require far more programming skills, and a Maker subscription to give you access to that widget.
Oh ok got it .Thanks
