I’m having a sudden problem that my automation does not trigger anymore.
It’s set to check once every second, yet it only triggers once after creation and after that never again.
Value is less than 1000ppm and still it does not start
Automations are triggered only once when the condition is changed. It will be triggered only when the condition goes back higher 1000and then will be < 1000 again. Unless the condition is “any” or “changed”
