Here is a suggestion about automation control :
for some devices or projects, end users do not need to have control over automations, or even to know what automations are.
it would be great to add a switch ‘show automation’ in the device control panel :
- if ‘on’, the ‘automations’ menu shows on terminal, as well as the ‘show automation’ button when automation message pops up, to allow the user to select with/without automation, exactly as it is now.
- if ‘off’, device automation is under control of programmer only, and fully hidden from the app (end user can’t disable automations) : no automations menu, no automation button
thank you,
Bruno
