Ok, I’m getting to work and reporting results!
First I wiped out an unnecessary library and left only onewire.h … Then I just went to examples and there I found an example for the DS18B20, and I copied a part of void loop code into my code …
#include <OneWire.h>
#define ONE_WIRE_BUS 2
OneWire ds(D2); // on pin 10 (a 4.7K resistor is necessary)
const int trigPin = D0;
const int echoPin = D1;
long duration;
int distance;
int temperature;
char pass[] = "YourPassword";
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
BLYNK_READ(V1)
//merenje rastojanja - measuring distance
//dojavljuje eventoru rastojanje - announces distance to the eventor
distance = param.asFloat();
serial.println(distance);
BLYNK_READ(V2)
//merenje temperature - measuring temperature
//dojavljuje eventoru temperaturu vode - announces water temperature to the eventor
celsius = param.asFloat();
serial.println(celsius);
//rastojanje - reading the distance
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
distance = duration*0.034/2; //razdaljina u cm
//temperature
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
break;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
However, now there is still one mistake, which is:
Arduino: 1.8.5 (Windows 10), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, 115200, 4M (3M SPIFFS)"
In file included from C:\Users\Denis HD\Documents\Arduino\automatski_bojler.ino\automatski_bojler.ino.ino:2:0:
C:\Users\Denis HD\Documents\Arduino\libraries\OneWire/OneWire.h:108:2: error: #error "Please define I/O register types here"
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
So the software asks me to define the I / O registers, but I do not know how to define them because I did not do it before …
This isn’t. Blynk issue.
The error message you’re getting is telling you about a problem with your OneWire library file. It gives you the location and name of the file that requires attention, and I think the 108 in the error message refers to the line number within that OneWire.h file.
I seem to recall some compatibility issues with the original Inewire library and the ESP8266, so it’s possible that you’re using a version of the library that’s incompatible with your hardware.
As I said, it’s not Blynk related, so maybe do a bit of googling?
So you ignored my valuable advice.
Use a decent DS18B20 tutorial and test it without Blynk Arduino Project Hub
As a novice to Blynk restrict loop() to just 2 lines as per the PUSH_DATA example.
@Costas I did not ignore your advice, I tried to fix what I can … and I found on another forum that the problem is in the folder name …
Or if you do not want to read everything from that forum, here’s a quote in which solution:
[quote] I used only the “DS18x20” example sketch.
But you said you got an error regarding IO registers? This means your IDE is using the “normal” OneWire" library located under your “Documents\arduino\libraries” folder, instead of the modified library located in your arduino program folder… (for me, this would be c:\arduino-1.6.1-esp8266\libraries\OneWire for the modified library, and NOT c:\users\dennis\documents\arduino\libraries\OneWire which is the wrong one!!).
(you can see which library path is used, when you enable verbose output for compiling in the arduino IDE, and check the output when testing the sketch). If the library used is the original one, it will fail. In this case I recommend to remove the original “OneWire” folder from your user arduino folder, then restart IDE - and it will use the modified OneWire library.[/quote]
Everything might work out, but now I have a HDD problem because it’s full … so I’ll probably postpone this code writing, so for a couple of days when I buy a second HDD of higher capacity, I’ll try once again to do everything you advised me , and I announce the results …
You did and you ignored the same advice on the other forum you linked to: VERBOSE.
Sorry, my mistake … Now it prints a mistake, that there is no library called OneWire.h, so it probably is not a good library, as @PeteKnight said …
D:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\Denis HD\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\Denis HD\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\sketchbook\libraries -fqbn=esp8266:esp8266:nodemcu:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021 -warnings=none -build-cache C:\Users\DENISH~1\AppData\Local\Temp\arduino_cache_404259 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\automatski_bojler.ino\automatski_bojler.ino.ino
D:\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\Denis HD\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\Denis HD\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\sketchbook\libraries -fqbn=esp8266:esp8266:nodemcu:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10805 -build-path C:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021 -warnings=none -build-cache C:\Users\DENISH~1\AppData\Local\Temp\arduino_cache_404259 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\automatski_bojler.ino\automatski_bojler.ino.ino
Using board 'nodemcu' from platform in folder: C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021\sketch\automatski_bojler.ino.ino.cpp" -o "nul"
"C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10805 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021\sketch\automatski_bojler.ino.ino.cpp" -o "C:\Users\DENISH~1\AppData\Local\Temp\arduino_build_291021\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\automatski_bojler.ino\automatski_bojler.ino.ino:2:21: fatal error: OneWire.h: No such file or directory
compilation terminated.
exit status 1
The verbose message you have is indicating that you failed to install the correct libraries.
OneWire works fine with ESP8266’s.
@Costas & @Gunner I installed the OneWire.h library, but afterwards the software wrote to me that I had to install the library for ESP8266, and finally, when I wanted to compile, I was told the next error is:
C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\automatski_bojler.ino\automatski_bojler.ino.ino: In function 'void BlynkWidgetRead1(BlynkReq&)':
automatski_bojler.ino:46: error: 'param' was not declared in this scope
automatski_bojler.ino:47: error: 'serial' was not declared in this scope
C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\automatski_bojler.ino\automatski_bojler.ino.ino: In function 'void BlynkWidgetRead2(BlynkReq&)':
automatski_bojler.ino:54: error: 'celsius' was not declared in this scope
automatski_bojler.ino:54: error: 'param' was not declared in this scope
automatski_bojler.ino:55: error: 'serial' was not declared in this scope
Using library OneWire at version 2.3.3 in folder: C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\sketchbook\libraries\OneWire
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Denis HD\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Using library Blynk at version 0.5.0 in folder: C:\Users\Denis HD\Documents\Arduino-NodeMCU0.9\sketchbook\libraries\Blynk
exit status 1
What???
In this tutorial everything works properly, I do not understand why it will not work in my code, when I installed all the necessary libraries?
Do you have the widgets for V1 and V2 set with a PUSH frequency or a timed frequency?
In this tutorial, she did not have to define Celsius, Param, serial …
As far as compiling errors involving Libraries… well, Arduino library structure and use is somewhat particular… You need to be precise, avoid too many variations of same libraries, follow clear folder structure, etc.
Thos errors seem to imply that something is still messed up in your sketch syntax and/or Arduino library structure… this time with one of the Blynk libraries as “param” would otherwise be recognised as a Blynk variable, not a random one.
This is simply something you need to learn and work out for ANY Arduino program… it is NOT a Blynk specific issue and can be hard for us to troubleshoot, as your PC and layout will be somewhat different then everyone else’s.
V1 and V2 in the application were set in the eventor, so I could not set a frequency there.
Zdravo Denise, dobrodošao na forum. Da li si potpuno siguran da imaš NodeMCU v0.9? Na ovim prostorima se taj modul ne prodaje već prilično dugo, v1.0 je aktuelan po oglasima bar godinu dana. To bi moglo da bude objašnjenje za neuspešno kompajliranje, pored duplo instaliranih OneWire biblioteka. Pored toga, rekao bih da je upotreba 10A releja za bojler veoma rizična, za te namene se koristi jači SSR od 40 ili 60A, ili bar ovo:
but don’t you have to create the V1 and V2 widgets before you can use them in Eventor.
It’s just that param is only available in BLYNK_WRITE (write to MCU) when using PUSH frequency and as far as I know param is not available in BLYNK_READ (read from MCU) at widget timed frequency.
If you use BLYNK_WRITE() you will need to use BlynkTimer or virtualWrite().
Pozdrav @zodiac sudeći po ovom oglasu, i po Arduino IDE, to bi trebalo da bude taj… Za relej sam mislio da koristim ovaj modul, pa da makar ta dva releja paralelno spojim radi veće snage… Elektro grejač je od 2kW, što po proračunima ne prelazi 8,5A (trebalo ni da “vuče” 8,33A pri naponu u kući od 240V)…
Biblioteke kao što rekoh, izbrisao sam sve što sam koristio za ovaj projekat instalirao, i ispočetka instalirao koje mi trebaju… tako da ne verujem da je u tome problem…
Imaš NodeMCU v1.0, kao što sam i pretpostavio. Ako odabereš v0.9 u Arduino IDE-u, nema šanse da kompajlira bilo šta. Takođe, bojler koristi grejač i jedan je od najjačih induktivnih potrošača u domaćinstvu, a nazivna snaga releja od 10A u stvarnosti podrazumeva maksimalno kratkotrajno optrećenje, realno to ne bi smelo da bude više od 4-5A u ovom slučaju. Paralelnim spajanjem releja nećeš postići ništa osim eventualnog požara, moja preporuka je Fotek SSR od 25, 40 ili 60A, na šta već prvo naiđeš, ima ih po oglasima. Uz njih ćeš morati da koristiš i odgovarajući hladnjak. Ako ti je to suviše komplikovano, preostaje ti ovaj klasičan relej od 30A, radi dobro i košta 500-600 dinara po oglasima.
