Hi fellow blynkers!
Thanks to @Costas code in this post, I’ve put together this:
Blynk App Demo
top part down to button Zone 5 OFF is output control, below Zone5 button is feedback telling you whether or not the zone actually turned on.
Code:
// Blynk Assignments //
V0 - Mode Switch
VX - Status LED :: Not working correctly, won't switch colors with app closed
V1X - Manual Switch
V2X - Auto Switch :: Time Input Channel
V3X - Actual Valve State
V4X - Channel Start Seconds
V5X - Channel Stop Seconds
V90 - Blynk App Notifications Enable/Disable
V100 - Controller Status
V101 - NowSeconds
V102 - Mode on Controller 1=OFF 2=Manual 3=Auto
V103 - NotifyStatus : for debugging will delete
V105 - WiFi Signal Strength
Thanks to @Costas:
https://community.blynk.cc/t/time-input-widget-and-eventor/14868/16
#include <blynk.h>
char auth[] = "****";
char currentTime[9];
bool clockSync = false;
unsigned int nowseconds = 999;
int mode = 0;
int manuel1 = 0;
int manuel2 = 0;
int manuel3 = 0;
int manuel4 = 0;
int manuel5 = 0;
int auto1 = 0;
int auto2 = 0;
int auto3 = 0;
int auto4 = 0;
int auto5 = 0;
int alertstatus = 1; //EEPROM location 1
int valve1state = 999; //999 is error status
int valve2state = 999;
int valve3state = 999;
int valve4state = 999;
int valve5state = 999;
// Zone valves
#define valve1 2
#define valve2 3
#define valve3 4
#define valve4 5
#define valve5 6
#define valve6 7
#define valve7 8
//int counts = 0;
#define GREEN "#008000"//"#23C48E"
#define BLUE "#04C0F8"
#define YELLOW "#ED9D00"
#define RED "#FF033E" //"#D3435C"
#define DARK_BLUE "#5F7CD8"
WidgetLED led1(V1);
WidgetLED led2(V2);
WidgetLED led3(V3);
WidgetLED led4(V4);
WidgetLED led5(V5);
BLYNK_WRITE(V90)
alertstatus = param.asInt();
EEPROM.put(50, alertstatus);
// Mode Selection //
BLYNK_WRITE(V0) {
switch (param.asInt())
case 1: // OFF
//Serial.println("Item 1 selected");
mode = 1;
offmode();
Blynk.virtualWrite(V100, "Mode: OFF");
EEPROM.put(1, mode);//not used--may use if Wifi issues and blynk_connect fails
break;
case 2: // Manual Mode
//Serial.println("Item 2 selected");
mode = 2;
manualmode();
Blynk.virtualWrite(V100, "Mode: Manual");
//led1.setColor(BLYNK_GREEN);
break;
case 3: // Automatic Mode
//Serial.println("Item 3 selected");
mode = 3;
automode();
Blynk.virtualWrite(V100, "Mode: Automatic");
break;
default:
//Serial.println("Unknown item selected");
mode = 999;
// Manual Buttons //
BLYNK_WRITE(V11)
manuel1 = param.asInt();
if (mode == 2 || mode == 3)
if (manuel1 == 1)
digitalWrite(valve1, LOW);
led1.setColor(GREEN);
Blynk.virtualWrite(V100, "Zone 1 Turning On");
digitalWrite(valve1, HIGH);
led1.setColor(RED);
Blynk.virtualWrite(V100, "Zone 1 Turning Off");
if (mode == 1)
Blynk.virtualWrite(V11, 0);
Blynk.notify("Select Manual or Auto Mode");
BLYNK_WRITE(V12)
manuel2 = param.asInt();
if (manuel2 == 1)
digitalWrite(valve2, LOW);
led2.setColor(GREEN);
Blynk.virtualWrite(V100, "Zone 2 Turning On");
digitalWrite(valve2, HIGH);
led2.setColor(RED);
Blynk.virtualWrite(V100, "Zone 2 Turning Off");
if (mode == 1)
Blynk.virtualWrite(V12, 0);
BLYNK_WRITE(V13)
manuel3 = param.asInt();
if (manuel3 == 1)
digitalWrite(valve3, LOW);
led3.setColor(GREEN);
Blynk.virtualWrite(V100, "Zone 3 Turning On");
digitalWrite(valve3, HIGH);
led3.setColor(RED);
Blynk.virtualWrite(V100, "Zone 3 Turning Off");
if (mode == 1)
Blynk.virtualWrite(V13, 0);
BLYNK_WRITE(V14)
manuel4 = param.asInt();
if (manuel4 == 1)
digitalWrite(valve4, LOW);
led4.setColor(GREEN);
Blynk.virtualWrite(V100, "Zone 4 Turning On");
digitalWrite(valve4, HIGH);
led4.setColor(RED);
Blynk.virtualWrite(V100, "Zone 4 Turning Off");
if (mode == 1)
Blynk.virtualWrite(V14, 0);
BLYNK_WRITE(V15)
manuel5 = param.asInt();
if (manuel5 == 1)
digitalWrite(valve5, LOW);
led5.setColor(GREEN);
Blynk.virtualWrite(V100, "Zone 5 Turning On");
digitalWrite(valve5, HIGH);
led5.setColor(RED);
Blynk.virtualWrite(V100, "Zone 5 Turning Off");
if (mode == 1)
Blynk.virtualWrite(V15, 0);
// Automatic Controls //
BLYNK_WRITE(V21) { // Scheduler #X Time Input widget
TimeInputParam t(param);
nowseconds = Time.local() % 86400;
unsigned int startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
unsigned int stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
Blynk.virtualWrite(V41, startseconds);
Blynk.virtualWrite(V51, stopseconds);
int dayadjustment = -1;
if(Time.weekday() == 1){
dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected((Time.weekday() + dayadjustment))){ //Time library starts week on Sunday, Blynk on Monday
//Schedule is ACTIVE today
if(nowseconds >= startseconds - 31 && nowseconds <= startseconds + 31 ){ // 62s on 60s timer ensures 1 trigger command is sent
//led1.setColor(BLUE);
Blynk.virtualWrite(V100, "Zone 1 Starting AUTOMODE");
Blynk.setProperty(V1, "color", BLUE);
Blynk.virtualWrite(V11, HIGH);
if(alertstatus ==1) {Blynk.notify("Zone 1 Starting AUTOMODE");}
if(nowseconds >= stopseconds - 31 && nowseconds <= stopseconds + 31 ){ // 62s on 60s timer ensures 1 trigger command is sent
//led1.setColor(YELLOW);
Blynk.virtualWrite(V100, "Zone 1 Stopping AUTOMODE");
Blynk.setProperty(V1, "color", YELLOW);
Blynk.virtualWrite(V11, LOW);
if(alertstatus == 1) {Blynk.notify("Zone 1 Stopping AUTOMODE");}
BLYNK_WRITE(V22) { // Scheduler #X Time Input widget
Blynk.virtualWrite(V42, startseconds);
Blynk.virtualWrite(V52, stopseconds);
Blynk.virtualWrite(V100, "Zone 2 Starting AUTOMODE");
Blynk.setProperty(V2, "color", BLUE);
Blynk.virtualWrite(V12, HIGH);
if(alertstatus ==1) {Blynk.notify("Zone 2 Starting AUTOMODE");}
Blynk.virtualWrite(V100, "Zone 2 Stopping AUTOMODE");
Blynk.setProperty(V2, "color", YELLOW);
Blynk.virtualWrite(V12, LOW);
if(alertstatus == 1) {Blynk.notify("Zone 2 Stopping AUTOMODE");}
BLYNK_WRITE(V23) { // Scheduler #X Time Input widget
Blynk.virtualWrite(V43, startseconds);
Blynk.virtualWrite(V53, stopseconds);
Blynk.virtualWrite(V100, "Zone 3 Starting AUTOMODE");
Blynk.setProperty(V3, "color", BLUE);
Blynk.virtualWrite(V13, HIGH);
if(alertstatus ==1) {Blynk.notify("Zone 3 Starting AUTOMODE");}
Blynk.virtualWrite(V100, "Zone 3 Stopping AUTOMODE");
Blynk.setProperty(V3, "color", YELLOW);
Blynk.virtualWrite(V13, LOW);
if(alertstatus == 1) {Blynk.notify("Zone 3 Stopping AUTOMODE");}
BLYNK_WRITE(V24) { // Scheduler #X Time Input widget
Blynk.virtualWrite(V44, startseconds);
Blynk.virtualWrite(V54, stopseconds);
Blynk.virtualWrite(V100, "Zone 4 Starting AUTOMODE");
Blynk.setProperty(V4, "color", BLUE);
Blynk.virtualWrite(V14, HIGH);
if(alertstatus ==1) {Blynk.notify("Zone 4 Starting AUTOMODE");}
Blynk.virtualWrite(V100, "Zone 4 Stopping AUTOMODE");
Blynk.setProperty(V4, "color", YELLOW);
Blynk.virtualWrite(V14, LOW);
if(alertstatus == 1) {Blynk.notify("Zone 4 Stopping AUTOMODE");}
BLYNK_WRITE(V25) { // Scheduler #X Time Input widget
Blynk.virtualWrite(V45, startseconds);
Blynk.virtualWrite(V55, stopseconds);
Blynk.virtualWrite(V100, "Zone 5 Starting AUTOMODE");
Blynk.setProperty(V5, "color", BLUE);
Blynk.virtualWrite(V15, HIGH);
if(alertstatus ==1) {Blynk.notify("Zone 5 Starting AUTOMODE");}
Blynk.virtualWrite(V100, "Zone 5 Stopping AUTOMODE");
Blynk.setProperty(V5, "color", YELLOW);
Blynk.virtualWrite(V15, LOW);
if(alertstatus == 1) {Blynk.notify("Zone 5 Stopping AUTOMODE");}
BLYNK_CONNECTED() {//get data stored in virtual pin V0 from server
Blynk.syncVirtual(V0);
Blynk.begin(auth);
Time.zone(-5); //-2.5
timer.setInterval(60000L, activetoday); // check every 60s if ON / OFF trigger time has been reached
timer.setInterval(1000L, clockDisplay); // check every second if time has been obtained from the server
timer.setInterval(10000L, sendinfo);
//Blynk.virtualWrite(V0, 2);
pinMode(valve1, OUTPUT);
pinMode(valve2, OUTPUT);
pinMode(valve3, OUTPUT);
pinMode(valve4, OUTPUT);
pinMode(valve5, OUTPUT);
pinMode(valve6, OUTPUT);
pinMode(valve7, OUTPUT);
//pinMode(valve8, OUTPUT);
digitalWrite(valve6, HIGH);
digitalWrite(valve7, HIGH);
//digitalWrite(valve8, HIGH);
firstrun();
void firstrun()
EEPROM.get(50, alertstatus);
Blynk.virtualWrite(V90, alertstatus);
void sendinfo()
Blynk.virtualWrite(V100, Time.format("%r - %a %D"));
Blynk.virtualWrite(V101, nowseconds);
Blynk.virtualWrite(V102, mode);
Blynk.virtualWrite(V103, alertstatus); //may delete
WiFiSignal sig = WiFi.RSSI();
float strength = sig.getStrength();
Blynk.virtualWrite(V105, strength);
valve1state = digitalRead(valve1);
valve1state = map(valve1state, 0, 1, 1, 0);//to deal with backwards relay
Blynk.virtualWrite(V31, valve1state);
valve2state = digitalRead(valve2);
valve2state = map(valve2state, 0, 1, 1, 0);//to deal with backwards relay
Blynk.virtualWrite(V32, valve2state);
valve3state = digitalRead(valve3);
valve3state = map(valve3state, 0, 1, 1, 0);//to deal with backwards relay
Blynk.virtualWrite(V33, valve3state);
valve4state = digitalRead(valve4);
valve4state = map(valve4state, 0, 1, 1, 0);//to deal with backwards relay
Blynk.virtualWrite(V34, valve4state);
valve5state = digitalRead(valve5);
valve5state = map(valve5state, 0, 1, 1, 0);//to deal with backwards relay
Blynk.virtualWrite(V35, valve5state);
void offmode()
led1.off();
led2.off();
led3.off();
led4.off();
led5.off();
void manualmode()
led1.on();
led2.on();
led3.on();
led4.on();
led5.on();
led1.setColor(RED);
led2.setColor(RED);
led3.setColor(RED);
led4.setColor(RED);
led5.setColor(RED);
void automode()
led1.on();
led2.on();
led3.on();
led4.on();
led5.on();
led2.setColor(YELLOW);
led3.setColor(YELLOW);
led4.setColor(YELLOW);
led5.setColor(YELLOW);
void activetoday(){ // check if schedule #1 should run today
if(mode == 3){
if(Time.year() != 1970){
Blynk.syncVirtual(V21); // sync scheduler #1
Blynk.syncVirtual(V22);
Blynk.syncVirtual(V23);
Blynk.syncVirtual(V24);
Blynk.syncVirtual(V25);
void clockDisplay(){ // only needs to be done once after time sync
if((Time.year() != 1970) && (clockSync == false)){
sprintf(currentTime, "%02d:%02d:%02d", Time.hour(), Time.minute(), Time.second());
Serial.println(currentTime);
clockSync = true;
Only trouble I’m having is led colors will not update when zones automaticlly turn on and blynk app is closed. More details here. I wonder if it’s not possible to Blynk.setProperty(V1, “color”, BLUE); inside blynk function?
