Ahhh i see, shit im so noob… hahahah
Tq @PeteKnight
Hola, antes que nada pido disculpas si no se puede escribir en otro idioma, pero vi que eres español y la verdad que no me llevo muy bien con el ingles.
Tu proyecto me encanto y lo estoy usando perfectamente, ahora queria saber si seria posible agregar un boton fisico para cambiar el estado manual de on a off?
si pudieras darme una mano con el codigo estaria encantado.
desde ya Muchas gracias
nice project, can you send your lastest code and QR code? thanks you
Help me, timer input is not working properly, today is Monday, I changed but the system kept your previous settings.
You have to adjust the day in your sketch.
For blynk, the first day of the week is Sunday, not monday.
Latest Status Eeprom Write. You check in there from the first boot.
Hi. love the project.
I’ve modified this project a fair bit to have time input to operate 2 separate irrigation zones. Managed to get it all working.
The next bit of functionality im keen to add is a ‘cycle/soak’ where the watering time is split up to allow time for the water to soak in before more water is added. My very crude attempt is to divide the total time input duration by 5 (3 running intervals and 2 soak intervals) and run a new function turning the relay on/off and then calling the next function (cycle_soak_1/2/3/4/5). You’ll see the first timer called in the “BLYNK_WRITE(V10)//Zone 1 time input handling” section and then the subsequent cycle_soak functions at the end of the V10 Write.
Some of the problems i’m having with this
- The 10second check doesnt seem to happen once the Zone 1 Cycle/Soak has kicked off (no updated on the terminal.
- reinstating to normal checking of the next input time doesnt appear to be working
A couple of notes
- i’ve only implemented the CYcle/soak on Zone1 at this stage for testing
- i’ve commented out some of the original code as im testing incase i need to retrieve later on
Any help, or better ideas on how to achieve would be greatly appreciated.
And thanks again for the project to begin with
// changes to allow cycle and soak in auto mode
* timeinput.ino Demonstrate interaction of Time library with
* Blynk's TimeInput widget.
* App project setup:
* RTC widget (no pin required!!!)
* V1 : Manual/auto1 button
* V2: On-off button
* Terminal on V3 // Label will be the clock + wifi signal!!!!
* Time Input widget on V10 (Auto)
* Button selection for Time Input (Auto) on V11
//#include <SimpleTimer.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
WidgetTerminal terminal(V3);
//#define server "blynk.cloud-com" // or "blynk.cloud-com" for Blynk's cloud server
#define TestLED 2 // on board LED pin assignment
char Date[16];
char Time[16];
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
long startsecondswd; // weekday start time in seconds
long stopsecondswd; // weekday stop time in seconds
long nowseconds; // time now in seconds
bool isFirstConnect = true;
String displaycurrenttimepluswifi;
int wifisignal;
int manual=0;
int oldstatus;
int zone1 = 4; // digital pin for relay 1
int zone2 = 5; // digital pin for relay 2
int auto1;
int zone1_state;
int zone2_state;
int timerID;
long cycle_soak_int;
pinMode(TestLED, OUTPUT);
digitalWrite(TestLED, LOW); // set LED OFF
digitalWrite(zone1, LOW);
digitalWrite(zone2,LOW);
pinMode(zone1,OUTPUT);
pinMode(zone2,OUTPUT);
Serial.println("\Starting");
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
break;
rtc.begin();
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V6);
Blynk.syncVirtual(V1);
timer.setInterval(10000L, activetoday); // check every 10 SECONDS if schedule should run today
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
timer.setInterval(5000L, clockvalue); // check value for time
timer.setInterval(5000L, sendWifi); // Wi-Fi singal
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void sendWifi() {
wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100);
void clockvalue() // Digital clock display of the time
int gmthour = hour();
if (gmthour == 24){
gmthour = 0;
String displayhour = String(gmthour, DEC);
int hourdigits = displayhour.length();
if(hourdigits == 1){
displayhour = "0" + displayhour;
String displayminute = String(minute(), DEC);
int minutedigits = displayminute.length();
if(minutedigits == 1){
displayminute = "0" + displayminute;
displaycurrenttimepluswifi = " Clock: " + displayhour + ":" + displayminute + " Signal: " + wifisignal +" %";
Blynk.setProperty(V3, "label", displaycurrenttimepluswifi);
void activetoday(){ // check if schedule should run today
if(year() != 1970){
if (auto1==1) {
Blynk.syncVirtual(V10); // sync timeinput widget
Blynk.syncVirtual(V20);
void checklastbuttonpressed (){
if((auto1==1)){ oldstatus=1;}
void restorelastbuttonpressed (){
if(oldstatus==1){auto1=1;}
//void resetTerminal()
// timer.setTimeout(50, checklastbuttonpressed);
// terminal.println();
// terminal.println("New MODE has been selected");
// terminal.println("Wait for update (Max 10 Seconds)");
// terminal.println("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~");
// terminal.flush();
void resetManual()
Blynk.virtualWrite(V1, 0); //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V2, 0); //Turn OFF Button Widget Device
Blynk.virtualWrite(V6, 0); //Turn OFF Button Widget Device
digitalWrite(zone2, LOW);
BLYNK_WRITE(V1) // Manual/auto selection
if (param.asInt()==1) {
manual=1;
terminal.println();
terminal.println("Manual MODE is ON");
terminal.println("Press Zone ON/OFF buttons as required");
terminal.println();
terminal.flush();
checklastbuttonpressed ();
auto1=0;
restorelastbuttonpressed ();
manual=0;
//timer.setTimeout(50, resetTerminal);
timer.setTimeout(50, resetManual);
auto1=1;
terminal.println();
terminal.println("Manual MODE is OFF");
terminal.println("Auto MODE restored from last status");
terminal.println();
terminal.flush();
BLYNK_WRITE(V2) // Zone 1 ON-OFF Manual
if (param.asInt()==1) { // boton encendido
terminal.println();
terminal.println("Zone 1 is ON");
terminal.println();
terminal.flush();
if (manual==0){ //está en modo auto1mático
manual=1;
auto1=0;
digitalWrite(TestLED, HIGH); // set LED ON
digitalWrite(zone1, HIGH);
Blynk.virtualWrite(V2, 1); //Turn ON Button Widget
Blynk.virtualWrite(V1, 1); //Turn OFF Auto Mode
} else { //está en modo manual
auto1=0;
}else {
terminal.println();
terminal.println("Press ON/OFF button if required");
terminal.println("Zone 1 is OFF");
terminal.println();
terminal.flush();
if (manual==0){ //modo auto1mático
manual=1;
auto1=0;
auto1=0;
BLYNK_WRITE(V6) // Zone 2 ON-OFF Manual
terminal.println();
terminal.println("Zone 2 is ON");
terminal.println();
terminal.flush();
manual=1;
auto1=0;
digitalWrite(zone2, HIGH);
Blynk.virtualWrite(V6, 1); //Turn ON Button Widget
auto1=0;
}else {
terminal.println();
terminal.println("Zone 2 is OFF");
terminal.println();
terminal.flush();
manual=1;
auto1=0;
auto1=0;
if (auto1==1) {
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
TimeInputParam t(param);
terminal.println("GENERAL:");
terminal.println(String(" Time zone: ") + t.getTZ()); // Timezone is already added to start/stop time
terminal.println(" Ensure at least ONE day is selected for each zone");
terminal.println();
terminal.println("ZONE 1:");
terminal.print(" Schedule checked at: ");
terminal.println(Time);
terminal.flush();
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
terminal.println(" Auto ACTIVE today");
terminal.println(" Cycle/Soak Active. 3 equal intervals of watering split up by 2 equal intervals of soak");
terminal.flush();
if (t.hasStartTime()) // Process start time
if(t.getStartMinute()<10){
terminal.println(String(" Scheduled Start: ") + t.getStartHour() + ":0" + t.getStartMinute());
}else{
terminal.println(String(" Scheduled Start: ") + t.getStartHour() + ":" + t.getStartMinute());
terminal.flush();
if (t.hasStopTime()) // Process stop time
if(t.getStopMinute()<10){
terminal.println(String(" Scheduled Stop : ") + t.getStopHour() + ":0" + t.getStopMinute());
}else{
terminal.println(String(" Scheduled Stop : ") + t.getStopHour() + ":" + t.getStopMinute());
int durationwd = ((t.getStopHour()*3600 + t.getStopMinute()*60 + t.getStopSecond()) - (t.getStartHour()*3600 + t.getStartMinute()*60 + t.getStartSecond()))/60;
cycle_soak_int = (durationwd*60*1000)/5;
terminal.print(" Total Duration (mins):");
terminal.println(durationwd);
terminal.print(" Total Watering Time over 3 intervals (mins):");
terminal.println((cycle_soak_int/1000/60)*3);
terminal.print(" Total Soak Time over 2 intervals (mins):");
terminal.println((cycle_soak_int/1000/60)*2);
terminal.flush();
// Display timezone details, for information purposes only
terminal.flush();
// for (int i = 1; i <= 7; i++) { // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
// if (t.isWeekdaySelected(i)) {
// terminal.println(String("Zone 1 Days ") + i + " is selected");
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
//Serial.println(startsecondswd); // used for debugging
if(nowseconds >= startsecondswd){
terminal.print(" Auto STARTED at");
terminal.println(String(" ") + t.getStartHour() + ":0" + t.getStartMinute());
}else{
terminal.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
terminal.flush();
if(nowseconds <= startsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
Serial.println("Zone 1 active");
timer.deleteTimer(timerID);
timerID = timer.setTimeout(cycle_soak_int, cycle_soak_1);
Serial.print("Cycle for: ");
Serial.print(cycle_soak_int/1000/60);
Serial.println(" minutes");
// code here to switch the relay ON
else{
Blynk.virtualWrite(V2,0);
terminal.println();
terminal.println(" Auto NOT STARTED today");
terminal.flush();
stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
//Serial.println(stopsecondswd); // used for debugging
if(nowseconds >= stopsecondswd){
terminal.print(" Auto STOPPED at");
terminal.println(String(" ") + t.getStopHour() + ":0" + t.getStopMinute());
}else{
terminal.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
terminal.flush();
if(nowseconds <= stopsecondswd + 90){ // 90s on 60s timer ensures 1 trigger command is sent
// code here to switch the relay OFF
else{
terminal.println(" Auto is ON");
terminal.flush();
else{
terminal.println();
terminal.println(" Auto INACTIVE today");
terminal.flush();
// nothing to do today, check again in 30 SECONDS time
terminal.println();
void cycle_soak_1(){
Serial.print("Soak for : ");
timerID = timer.setTimeout(cycle_soak_int, cycle_soak_2);
void cycle_soak_2(){
Serial.print("Cycle (2nd) for: ");
timerID = timer.setTimeout(cycle_soak_int, cycle_soak_3);
void cycle_soak_3(){
Serial.print("Soak (2nd) for: ");
timerID = timer.setTimeout(cycle_soak_int, cycle_soak_4);
void cycle_soak_4(){
Serial.print("Cycle (3rd) for: ");
timerID = timer.setTimeout(cycle_soak_int, cycle_soak_5);
void cycle_soak_5(){
Serial.print("End of cycle/soak");
BLYNK_WRITE(V20)//Zone 2 time input handling
if (auto1==1) {
terminal.println("ZONE 2:");
terminal.flush();
if(weekday() == 1){
terminal.flush();
}else{
terminal.flush();
}else{
terminal.print(" Duration (mins):");
terminal.flush();
// terminal.println(String("Time zone offset: ") + t.getTZ_Offset()); // Get timezone offset (in seconds)
terminal.flush();
// terminal.println(String("Zone 2 Days ") + i + " is selected");
}else{
terminal.flush();
else{
Blynk.virtualWrite(V6,0);
terminal.println();
terminal.flush();
}else{
terminal.flush();
else{
terminal.flush();
else{
terminal.println();
terminal.flush();
terminal.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG("Reconnected");
BLYNK_LOG("Not reconnected");
if (Blynk.connected()) {
Just water 1 minute exactly every other day …
And tell me to the beginner, if this project is used on the ESP8266 Nodemu Board, then what output of the Board will receive a signal?
@rusl143 I’d suggest that you start with a simpler project to enable you to obtain a better understanding of how the hardware and code that you are using work together.
The Sketch Builder has some very easy to follow examples and can be found here:
https://examples.blynk.cc/
Once you’ve played around with several of these and got them to work in the way that they are intended, and maybe make a few changes to understand better how they are working, then come back and look at their project again.
Hi psoro,
great timer!
how may I integrate sunrise and sunset to your code.
I am getting a number on the teminal
This is what I use in my weather station code
long sys_sunrise = sys["sunrise"]; // json return value for sunrise
String Sunrise = String(hour(sys_sunrise)) + ":" + String(MyPrintDigits(minute(sys_sunrise)));
long sys_sunset = sys["sunset"]; // json return value for sunset
String Sunset = String(hour(sys_sunset)) + ":" + String(MyPrintDigits(minute(sys_sunset)));
//add '0' before digit
String MyPrintDigits(int digits) {
String new_digits = "";
if (digits < 10) new_digits += "0";
new_digits += String(digits);
return new_digits;
Thanks Blynk_Coeur but how and where should I include this in below code supplied by psoro back in the day, do I need to install any json libraries?
psoro’s code: curtesy psoro
@Altech I’ve removed the code you posted because you didn’t format it with triple backticks at the beginning and end of the code.
sorry i am new to this- thanks for telling me!
thanks Blynk_Coeur, how do i integrate your piece of code to below which was supplied by psoro?
@Altech I gave you some triple backticks to copy/paste, but instead you chose to invent your own version - which didn’t work, so your code has been deleted again.
Once again, triple backticks look like this:
does copying your triple back ticks in place of my tripple back ticks work?
