I am using Arduino Mega (Arduino Version 1.8.9) and ESP8266 as wifi shield. Blynk is set up to read temperature measurements and also to take inputs which actuate servo valves. I have the ESP8266 core installed and libraries Blynk Library Master
Everything is working fine with the exception that the wifi connection will at times break down and I need get the arduino to automatically reconnect to wifi and Blynk. I read what I could find and believe to understand how to use " Blynk.connectWifi(ssid, pass);" and âBlynk.config(auth);â in the loop function to accomplish that.
My issue is the code does not even compile. It throws errors on the âBlynk.wifiâ command such as error: âclass BlynkWifiâ has no member named âconnectWifiâ - as if it cannot find the correct library. However I do not see which library is missing. Feels to me as if I am overlooking sth obvious⌠Thanks for your help. Code and full error log below.
// BLYNK
#include <ESP8266_Lib.h> // download https://github.com/blynkkk/blynk-library
#include <BlynkSimpleShieldEsp8266.h> // download https://github.com/blynkkk/blynk-library
#include <SimpleTimer.h> // download https://github.com/jfturcot/SimpleTimer
#define EspSerial Serial1
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void setup();
// Set ESP8266 baud rate
// BLYNk
timer.setInterval(2000L, myTimerEvent);
if (Blynk.connected()) {
else {
if (WiFi.status() == WL_CONNECTED){
Blynk.config(auth);
Blynk.connect();
Compilation Error:
Arduino: 1.8.9 (Windows 10), Board: âArduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)â
\united.domain\homes\Karlsruhe\msteinberg\Eigene Dateien\21 Privat\02 Brewing\CloudBrewery2018_v27\CloudBrewery2018_v27.ino: In function âvoid loop()â:
CloudBrewery2018_v27:586:9: error: âclass BlynkWifiâ has no member named âconnectWifiâ
CloudBrewery2018_v27:587:7: error: âWiFiâ was not declared in this scope
CloudBrewery2018_v27:587:24: error: âWL_CONNECTEDâ was not declared in this scope
CloudBrewery2018_v27:588:26: error: no matching function for call to âBlynkWifi::config(char [33])â
Blynk.config(auth);
In file included from \united.domain\homes\Karlsruhe\msteinberg\Eigene Dateien\21 Privat\02 Brewing\CloudBrewery2018_v27\CloudBrewery2018_v27.ino:329:0:
\united.domain\homes\Karlsruhe\msteinberg\Eigene Dateien\21 Privat\03 Arduino\arduino-1.8.9\libraries\BlynkESP8266_Lib/BlynkSimpleShieldEsp8266.h:169:10: note: candidate: void BlynkWifi::config(ESP8266&, const char*, const char*, uint16_t)
void config(ESP8266& esp8266,
\united.domain\homes\Karlsruhe\msteinberg\Eigene Dateien\21 Privat\03 Arduino\arduino-1.8.9\libraries\BlynkESP8266_Lib/BlynkSimpleShieldEsp8266.h:169:10: note: candidate expects 4 arguments, 1 provided
exit status 1
