I used connect success to blynk 2.0.
But recently I met below issue.
After connected to Blynk2.0. My esp8266 auto reset as my image.
Please help me this case
Are you using Digital datastreams?
If so you should read this…
When using an ESP8266 based board (NodeMCU, Wemos D1 Mini, ESP-01 etc) if a digital datastream is added which uses pin 6 to 11 the device will go through a constant cycle of connecting to Blynk then rebooting, like this…
12:50:51.658 -> [68] Connecting to REDACTED
12:50:55.902 -> [4299] Connected to WiFi
12:50:55.902 -> [4299] IP: 192.168.1.6
12:50:55.902 -> ___ __ __
12:50:55.902 -> / _ )/ /_ _____ / /__
12:50:55.902 -> / _ / / // / _ \/ '_/
12:50:…
Thank you so much for your support
