hi,
i installed local Blynk server on my raspberry. everything work. right now i have issue with sending auth tokens from mobile while I am connected to Blynk.
i tried to change mail.properties for ssl to false and change port to 25 but i have the same problem.
also,
i try with other local mail but problem is the same.
I think that getting mail to work on local server can be quite tricky. I assume that you’ve read the documentation, including the bit about setting Gmail to allow less secured applications?
There are two simple workarounds…
- copy the auth token from the local server admin screen or
- copy the auth token from the app and email it to yourself from your phone’s email client.
it is workaround but it should work from the app.
i created also gmail with less secured access.
