@vshymanskyy
Dear vhymanskyy, several months ago, following your suggestion, I uncommented the line “#define BLYNK_USE_128_VPINS” in file config.h in order to deal with 128 pins on my ATmega 328.
Everything has gone ok until I have updated the library. Now this workaround doesn’t work anymore. I have errors at compile time (… virtual pins 32 not defined …).
I have noticed that now the file config.h is inside the directory Blynk/src/Blynk instead before it was simply inside Blynk.
Can you please help me? It’s very important …
Thanks a lot,
Giancarlo
