Asia Server down
these are a few api calls. one took 16sec and the other one gave request timeout error
server normally n work perfectly for now
status disconnected.
from Thailand
ws://blynk-cloud.com/websockets:80 is down. Kindly assist.
APIs have started working.
@Dmytro it seems that websockets aren’t working on the newly repaired Asian server, so Node-Red users have no connectivity.
API is also not working properly. The same issue. It either takes too long to respond or does not respond at all.
@Dmytro Were you able to look into this one?
Could you please check again? I did a possible fix.
@Jasraj could you please check one more time? Seems like latency is returned to normal.
working. thanks!
Yes. Throughout the day, I didn’t encounter the problem.
Ok, cool. So looks like the root problem was caused by the update of the underlying networking library. I’ll investigate further.
Again websocket url is down. Kindly look into the issue.
@Dmytro Any thoughts on this one? It happened again.
Hi @Dmytro - Websokets are still not working today. Were you able to investigate further?
@vishalavalani what url do you use?
This started working when you fixed but not working since yesterday morning. Something has gone wrong.
I did a redeploy. But I don’t see any issues right now, I see websocket connections coming in. Strange.
@vishalavalani I have one idea. try to remove the port:
Works without applying port. Should I change socket url or are you making it work with port 80 still? Request you to confirm. thanks!
