Looking into it.
Looks it isnāt working in Dubaiā¦
Also in Israelā¦
in Jordan, too!
Is the app working ?.. I couldnāt control my lights for some reason and I had to reset all my nodemcuāsā¦still no luck.
The issue is fixed. We changed the server to new instance type so this particular issue will never happen again. Sorry for inconveniences.
Still the servers are down. App and project nothing is working.
Right now, my App and devices are running fine:
Pinging blynk-cloud.com [188.166.206.43] with 32 bytes of data:
Reply from 188.166.206.43: bytes=32 time=336ms TTL=50
Reply from 188.166.206.43: bytes=32 time=355ms TTL=50
Reply from 188.166.206.43: bytes=32 time=377ms TTL=50
Reply from 188.166.206.43: bytes=32 time=348ms TTL=50
Ping statistics for 188.166.206.43:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 336ms, Maximum = 377ms, Average = 354ms
Did you hardcode some IPs maybe? What error do you see?
The app can run normally after logging out and logging in again, thank you!
It works as usual using app. But with API it either takes too long(upto 15 seconds) or doesnāt work at all.
server is not stable⦠its not working now⦠not working from API n Apps tooā¦
my project not working for now
@erickfloors I donāt see any troubles with the server right now. What exactly doesnāt work? Do you see some error? Endless spinning dots?
my call is using the ip address
Sometimes it works really fast. it gives response in ~80ms. and sometimes it takes more than 15 secs. or shows ECONRESET Error.
