This is just a snippet of my application to zoom in on the problem.
What I would like to do is change a few variables up top and have that configure the stuff down below. That way I can keep just one code base for a dozen devices. But maybe I don’t really understand how variables work. I have spent about two weeks on this and have tried about a million variations that I have found online. The current error is:
/Users/jabbott/Documents/Arduino/sketch_feb13a/sketch_feb13a.ino: In function ‘void setup()’:
sketch_feb13a:18:30: error: invalid conversion from ‘char’ to ‘const char*’ [-fpermissive]
But I have had lots of errors. You should be able to figure out what I am trying to do below even if it doesn’t compile.
–ja
#define ROOM 1
#define LOCATION 1
const char my_ssid[] = { 'The Abbotts', 'Flints_Realm', 'Horners Corner' } ;
const char my_pass[] = { 'th3XXXXXX, 'PupXXXXXX', 'mapXXXXX' };
const char poss_auth[] = { 'CGlXXXXXXXLmxTZvqPoa4YGL3TDoQ6S', '0cpCeyQIGXXXXXX5cB0u9_SLDuCD', 'Emiw5PYmeXpXXXXX0kSEzt91nyadv' };
char auth = poss_auth[ROOM];
char ssid = my_ssid[LOCATION];
char pass = my_pass[LOCATION];
