Trying to connect new particle argon with new Blynk app. When I go to add device it searches but prompts me to WiFi network settings to select device however I do not see the device ever appear. I used the particle app to connect argon to local WiFi prior?? Can someone please help me
It appears others have been able to connect the Argon device in your community. I will try again with Photon tonight but I was not able to connect that one either. Do the devices need to have code flashed on them for Blynk to connect to device? Very confusing process.
I really hope your team immediately improves the Particle device connection and accepts their new versions of Boron and Argon as myself and others I know prefer this microcontroller and use it almost exclusively.
@Mlaird please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
