BLYNK
Arduino + w5100 ethernet shield error
hello friends I have a problem related to the ethernet shield
I use library blynk v0.3.8
constantly waiting for that
[0] Blynk v0.3.8 on Arduino Uno
[0] Getting IP…
[60460] DHCP Failed!
[0] Getting IP…
  • Blynk is a platform with iOS and Android apps to control
  • Arduino, Raspberry Pi and the likes over the Internet.
  • You can easily build graphic interfaces for all your
  • projects by simply dragging and dropping widgets.
  • Downloads, docs, tutorials: http://www.blynk.cc
  • Blynk community: http://community.blynk.cc
  • Social networks: http://www.fb.com/blynkapp
  •                           http://twitter.com/blynk_app
  • Blynk library is licensed under MIT license
  • This example code is in public domain.
  • This example shows how to use Arduino Ethernet shield (W5100)
  • to connect your project to Blynk.
  • Feel free to apply it to any other example. It’s simple!
  • NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
  •   DON'T use them in your sketch directly!
  • WARNING: If you have an SD card, you may need to disable it
  •   by setting pin 4 to HIGH. Read more here:
  •   https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
char auth[] = “9620*****************4bd9d88”;
Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, “your_server.com”, 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
I had a problem with reset W5100
first solution
http://www.hobbyist.co.nz/?q=ethernet-shield-w5100
it’s my solution problem
after that works fine
I still have not Execute
Hi guys,
@krzyspx I faced thesame issue with thesame board hunrun 16/02 but i got the solution for this problem.
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xA2, 0xBE, 0xEF, 0xAE, 0xAB
IPAddress ip(192, 168, 1, 99);
byte gateway[] = { 192, 168, 1, 1 };
// the subnet:
byte subnet[] = { 255, 255, 255, 0 };
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print("Use the I.P to open this from web Browser para ma test ang Net module ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  EthernetClient client = server.available();
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println("<p>Ethernet Module is Working fine! Network Module is Ready to accept project sketch... Net Test By Castle Marc*****</p>");
          client.println("</html>");
          break;
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
try to load the sketch above then type your ethernet shield i.p to your net broser and you should see some message. if not follow steps below.
1.) Replace your LAN cable.
2.) make sure your network switch or router port is 8 pins available. normmaly for dlindk 4 port or 8 port switch you can see the 8 pins leads,
but for other common brand like TP-link and other generic network switch no will notice that there are 4 pin leads only inside the port.
3.) Ping your ethernet shield if you able to communicate after 1 & 2 steps is verified.
Hope this can help. mine is solved i got 4 netwis5100 all of them or showing DHCP failed!!! but now. all up in running…
Hi guys,
byte mac[] = {
// the subnet:
  pinMode(4, OUTPUT);
  while (!Serial) {
  server.begin();
  if (client) {
        Serial.write(c);
          client.println();
          break;
        if (c == '\n') {
    client.stop();
Little side note, since the port is 10 mbit it’s useless to have the 8 pins. The 4 pins for 100mbit full duplex are more than enough to get connectivity. There is probably not a single vendor which doesn’t adhere to cat6 standards, so everything should be 8 wires.
The LAN cable tip is a very good one though!
Setting a fixed IP is not a solution if you ask me. It’ll only make things worse when you are troubleshooting later. The mission is to solve the problem.
Resetting a router might help, updating the firmware on your router.
And last tip, change the MAC address of the device via the sketch! Some devices and/or routers can get really wonky when they see the same MAC on two or more ports.
@tariktumanbay is your DHCP still not solved? Please update. I think it is solve because your not posting any comments any more , LOL… Enjoys Guys… Happy Blynking…
My problem was not solved and i quit trying :slight_smile: now I just started doing esp12e :slight_smile:
the method in the video works :star_struck:
