Hello Everyone, I am testing Blynk for my students so they can use it in a project. I have followed the instructions but the app is not connecting to the Arduino via USB I have entered the details via the Terminal on the Mac and seems to be connecting to the correct port.
Also checked logs from mobile device and found this error log:
2019/05/12 14:03:44:618 App sent net op 7101 with error: Error Domain=kACNetworkManagerErrorDomain Code=7 "Hardware is offline" UserInfo={NSLocalizedDescription=Hardware is offline, NSLocalizedFailureReason=Error}
Here is what the board is doing: https://youtu.be/WRbLWI2PLDk
Arduino UNO without Shield
• Smartphone OS (iOS ) 12.2
• Blynk server or local server? ( How can I tell?)
• Blynk Library version VO 6.1
• Add your sketch code.
Code should be formatted as example below.
http://twitter.com/blynk_app
=> USB HOWTO: http://tiny.cc/BlynkUSB
You can send/receive any data using WidgetTerminal object.
App project setup:
Terminal widget attached to Virtual Pin V1
#define BLYNK_PRINT SwSerial
char auth[] = "75f4d24ceee84765ab01df9d771994c6";
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr()) {
terminal.println("You said: 'Marco'") ;
terminal.println("I said: 'Polo'") ;
// Send it back
terminal.print("You said:");
terminal.write(param.getBuffer(), param.getLength());
terminal.println();
// Ensure everything is sent
terminal.flush();
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println(F("-------------"));
terminal.println(F("Type 'Marco' and get a reply, or type"));
terminal.println(F("anything else and get it printed back."));
terminal.flush();
