Hi, I’ve been trying to use Arduino UNO Wifi Rev2 with Blynk.
I’ve seen other threads on here about this and have tried their code but I’m getting large error messages. Can someone tell me where to look please?
It looks like a problem with SPI.h???
Code:
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = "6**************************e";
char ssid[] = "iPhone von M*****";
char pass[] = "g*************";
//char ssid[] = "G*************";
//char pass[] = "m***********";
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
Error messages:
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function ‘static void SpiDrv::begin()’:
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:87:24: error: ‘PINS_COUNT’ was not declared in this scope
if (SLAVERESET > PINS_COUNT) {
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:87:24: note: suggested alternative: ‘PING_CMD’
PING_CMD
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:97:15: error: ‘NINA_GPIO0’ was not declared in this scope
pinMode(NINA_GPIO0, OUTPUT);
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function ‘static int SpiDrv::available()’:
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:565:25: error: ‘NINA_GPIO0’ was not declared in this scope
return (digitalRead(NINA_GPIO0) != LOW);
exit status 1
Error compiling for board Arduino Uno WiFi.
