Arduino Uno /w w5100 shield not connecting to local server
full reedit:
concerns an Arduino Uno /w 5100 ethernet shield. Running following code:
void setup(){
  Serial.println("Deselect SD card...");
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
  Serial.println("Blynk Begin");
  Blynk.begin(auth, ssid, pass, server, port);
  Serial.println("Starting Blynk connection");
  Serial.println("Blynk connect");
  while (Blynk.connect() == false) {  }           // Wait until connected
  toTerminal("-------------");
  toTerminal(String("Blynk v") + BLYNK_VERSION + " started");
  initVPins();    //INIT VIRTUAL PINS
  timer.setInterval(TIME_RUN_FUNCTIONS, runFunctions);                               // every 1 minute: run time functions.
  runFunctions();        // make sure they also run on startup
void runFunctions(){
  Serial.println("run one minute functions");
  updateTerminalLAbel();                          // every 1 minute: update the label on the terminal (time/version)
  reconnectBlynk();                               // check every minute if still connected to server
  //checkDevices();                                 // do this also immediately on startup.
  //checkCentral();
void loop(){
gives me:
Deselect SD card...
Blynk Begin
[0] Using static IP
[1560] IP:192.168.1.93
[1561]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.5.3 on Arduino Uno
  Give Blynk a Github star! => https://github.com/blynkkk/blynk-library
[1756] Connecting to wolph42:670
[16819] Connecting to wolph42:670
etc. for every 10s or so.
any clue what Im doing wrong?
Note that I have a bunch (12) or ESP’s connected to the server all working dandy, somehow this arduino doesnt want to play ball…
Are those relevant to your Ethernet setup? ))
during my sleep I gathered the same thing: no they’re not, do you think thats the issue?
ok replaced with:
  Blynk.config(auth, server, port);
  Blynk.connect();
and now I get:
Deselect SD card…
Blynk Begin
[0]
___ __ __
/ _ / / // / _ / '/
//_, /////_
Give Blynk a Github star! => GitHub - blynkkk/blynk-library: Blynk library for IoT boards. Works with Arduino, ESP32, ESP8266, Raspberry Pi, Particle, ARM Mbed, etc.
[202] Connecting to 192.168.1.93
[5202] Connecting to 192.168.1.93
Blynk connect
[10203] Connecting to 192.168.1.93
[15204] Connecting to 192.168.1.93
[20205] Connecting to 192.168.1.93
etc. etc. etc;
I’d start with trying some of the basic code examples from the Sketch Builder to make sure it’s not a hardware issue.
These Ethernet shields are notoriously flaky and some don’t work with certain Ethernet switches.
https://examples.blynk.cc/?board=Arduino%20Uno&shield=Ethernet%20Shield%20W5100&example=GettingStarted%2FBlynkBlink
@wolph42, are you trying to use Blynk.begin() along with Blynk.config() and Blynk.connect() ?? If so, it is not a correct approach. I think you just forgot, that Blynk.begin() is a ā€œcomboā€ command and those latter are not necessary. You were active on this (below) topic too, so just a reminder:
@PeteKnight I did test the shield earlier on to see if I can ā€˜get connected’ this worked, I didn’t do this through blynk though, just created a simple webserver and checked that locally from another pc.
@marvin7, indeed I was, but not (yet) in the ethernet area. Thnx for the reminder.
No im not. .config() and .connect() in setup .run() in the loop. I was using .begin() in my very first attempt, to which @vshymanskyy replied. I changed it in my second attempt. Nonetheless, are you suggesting that I should try this:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  //you can edit it to your needs
if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
 Blynk.connect();
I will test this evening. Thank you both.
You should start with plain simple example of Blynk and Ethernet, and not mixing stuff with WiFi, etc.
