I am trying to get the new Arduino Uno R4 Wifi linked to a blynk project.
In the past, I have used ESP32’s with the blynk Edgent_ESP32 example code to get started and added my Template ID and Template Name and flashed it and it worked.
How do I get that far with the new Arduino Uno R4 Wifi?
There are no plans to support Edgent for this board.
You can, however, use Blynk.NCP which is a special flavor of Edgent for Dual-MCU boards, which is compatible with UNO R4 WiFi:
Just wanting to clarify before I commit to reflashing this.
Will the R4 WiFi still work for all the normal Arduino projects my students might be doing?
If not, what does or doesn’t work after a reflash?
If it does all work the same, but have the ability to connect via Blynk, is there any other downside or side effects I need to worry about with this, or plan ahead for with students working on many types of projects going forward?
