Arduino UNO not in network
I have uploaded the BlynkBlybk sketch:
Blynk lets you create beautiful drag-and-drop visual interfaces
for your projects in 5 minutes. And it works with almost every
hardware out there.
Docs, Tutorials, everything: http://www.blynk.cc
Github: blynkkk (Blynk IoT platform) · GitHub
Blynk Community: http://community.blynk.cc
Follow Us: Blynk
http://twitter.com/blynk_app
You’ll need, in general:
  • Blynk App (download from AppStore or Google Play)
  • Arduino UNO or similar microcontroller board
  • Decide how to connect Arduino to the Internet (USB, Ethernet,
    Wi-Fi, etc.). Bluetooth is on the way.
example.
Let’s turn ON your LED with Blynk!
In this example we’ll use Arduino UNO + Ethernet Shield
5 Steps guide:
(watch video tutorial here: )
  1. Connect LED to Pin 9
    ( http://arduino.cc/en/uploads/Tutorial/simplefade_bb.png )
In the Blynk App:
2. Create New Project
3. Email yourself Auth Token. You can do it later at any time
4. Add a Button Widget. Select Pin D9 in Widget’s Settings
5. Press Play icon. Enjoy Blynking!
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
char auth = “80df1d56e05c4d21b954ac95e0e88e97”; // Put your Auth Token here. (see Step 3 above)
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
Blynk.run(); // All the Blynk Magic happens here…
// to avoid delay() function!
I have run the blynk-ser.bat as instructed in the comments. Com 3 9600 baud cloud.blynk.cc etcetera
I get nothing but this in the serial monitor:
[0] Blynk v0.2.2
[0] Getting IP…
And when I hit play in the blynk app, I get Arduino Uno is not in network.
Connected by USB to the laptop. laptop is connected by wifi to the internet.
So you are connected over USB, but trying to use example for Ethernet Shield.
Please carefully follow every step in the USB example.
