If you set up your Hardware properly and you are able to connect your App to your Bluetooth device with the help of the BLE widget …
and if you followed the advices given here, which means that your code looks like this:
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
// to avoid delay() function!
Then you maybe run into the same problem like me and got the “SerialBLE was not declared in this scope” error.
So my workaround is very simple: forget SimpleBLE. All you need is the following code:
char auth[] = "your_token";
SwSerial.begin(9600);
Blynk.begin(SwSerial, auth);
