uno-ethernet shield-dht22 ok. how to Make uno-ethernet shield-DS18B20 dallaschip help please project
//dht22 ok
Was your problem solved?
BTW, you can post your code not as images. Just paste it here, select it and press </> button
#include "DHT.h"
#include <Ethernet.h>
#define DHTPIN 7 // The pin you connect to
#define DHTTYPE DHT22 // DHT 11 Change this if you have a DHT22
DHT dht(DHTPIN, DHTTYPE); // Change this to
char auth[] = "xxxxxxxxx";
Blynk.begin(auth);
timer.setInterval(2000, sendDHT);
void sendDHT()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
int hum = (int) h;
int tem = (int) t;
//Write values to V04 and V05
Blynk.virtualWrite(4, hum);
Blynk.virtualWrite(5, tem);
#include <OneWire.h>
//Data wire plugged to pin 7 (temp sensor)
#define ONE_WIRE_BUS 7
char auth[] = "xxxxxxxxxx";
Blynk.begin(auth);
sensors.begin();
timer.setInterval(3000, readTemp);
void readTemp()
float floatTempC = sensors.getTempCByIndex(0);
char t_buffer[15];
dtostrf(floatTempC, 8, 9, t_buffer);
Blynk.virtualWrite(5, t_buffer);
I guess, "DHTPIN 7 " and Ethernet pin are confusing them.
You may change “DHTPIN 7” to “DHTPIN 8”.
How would you add another ds18b20 sensor to your sketch?. I tried doing that but I’m not at that level yet.
http://forum.arduino.cc/index.php?topic=43535.0
This has some interesting information.
You should check out the example Dallas sketch from the Arduino library. It has two examples. One with a simple bus, a.k.a. all sensors on a seperate line (Multiple_simple example) and a Multiple example which deals with all devices on one bus. It’s a but more complicated, but it should work OK.
Thanx i got it working. Is it possible to use blink with bmp 180 ?
I don’t see why not. It’s a simple I2C device which should work perfectly fine with the Arduino and hence with Blynk.
