So first of my ESP can connect to the wifi but can’t get information from the DHT. It always says:
Failed to read from DHT sensor!
I’m using the DHT11 + Arduino + esp example code. Just changed the baudrates to 115200 (because only on that baudrate the esp could connect to wifi?).
I crossed the TX and RX wires, don’t know if this is ok. But atleast my ESP can connect to my wifi.
Does someone have an idea of what I’m doing wrong?
Regrettably that will not work. Uno, ESP and Blynk will not work together at 115200 so you must change the baud rate of the ESP.
Yes crossing tx and rx is ok but realise it might destroy the ESP if you don’t have a voltage divider on the ESP’s rx pin (Uno is kicking out 5V to the 3.3V ESP). Espressif Chairman states some ESP’s are 5V tolerant but a couple of resistors are only a few cents so probably not worth the risk.
Many users seems to wire up their sensors wrongly, worth checking.
Well but when using 9600 as Baudrate it always says that it cant connect. And im pretty sure I wired my sensor correctly, OUT to 2 Pin just as in the example sketch, gnd to gnd and vcc to 5v.
That’s because you haven’t sent the correct AT command to the ESP. Many ESP’s come from the factory set at 115200 (some at the odd 74800) rate because they work well at this speed if you don’t try to hook them up to an Arduino.
Not good. I can neither change the baudrate via AT commands nor update the firmware, its just not working for me. I probably already blew up tx and rx through the 5v’s from arduino. I think I’m going back to bluetooth and dump that stupid esp thing, just too time consuming.
I had not so good results that way. straight forward once i got the ftdi usb to serial.
Have you uploaded the bare minimum sketch first to ensure nothing is using the serial?
Have you tried to flash it using the esp flasher from https://espressif.com/ using the arduino port?
Mine worked without it for testing and setup. I do have it on external one now and running the serial through a logic level shifter as i was using software serial once it was setup but switched over to the hard serial and ran at a higher baud rate.
