Hello everyone,
First of all this is my first post here. I started adventure with arduino and programming 2 months ago. So I am new in this topics.
Untill now I realized few projects including Blynk connected with arduino. The last one was similar to one described in topic but I used the ENC28j60 instead of ESP8266 module and then it worked fine.
The problem started with ESP module…
Short description of project:
The main idea is to control AC light with Blynk App support.
First of all I made a connection according to picture below:
As power source I used the USB phone charger connected with step by voltage converter to get in final the 3.3V source.
I additionally connected the Arduino Uno with relay module like this:
Arduino ====> Relay module
5V ====> VCC
GND ====> GND
Pin 5 ====> IN1
Everythink you can see in picture below (sorry for quality)
And for now I did almost every step (with sooooo many problems :D). Here I mean:
- I checked if arduino is connected with ESP module by serial port -> system report “ready” status
- I upload the below (tample) Arduino IDE sketch for my project:
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
// Debug console--
- And finally I started the New project in Blynk. I set the Arduino uno as a hardware model and WiFi as connection type. Then I added the Button and set the Output to D5.
And now (close to the end of project) I met with a problem. After pushing the connect button (in up-right corner) I receive the information that device is connected (Online). Then when I try to push the button to Active Relay - nothing happens
Whats more. I tried with different pins on Arduino with the same results. And I don’t know why (probably because I have still small knowladge) but when I set the Button output value to D2 - after connection when I push it then the diod on ESP module Turn OFF and Turn ON.
I tried to find solution on this forum and in many other places for last 3 days but without any results. Thats why I decided to ask You for help. Do you know what did I wrong or what should I add to project to make connection between the Blynk and relay work correct?
Write if you will need some more or detailed informations from my side.
