Project with Android, Arduino Uno and serial usb D13 worked for 1 day. Went offline and could not get it back online. Deleted project and created again, uninstalled Blynk app and reinstalled app. Now I get error “Wasn’t on line yet” after pressing play button. This info is from pc.:\Users\Paul\Blynk v0.5.3\Blynk\scripts>blynk-ser.bat -c com3
Connecting device at com3 to blynk-cloud.com:80…
OpenC0C("\.\com3", baud=9600, data=8, parity=no, stop=1) - OK
Connect(“blynk-cloud.com”, “80”) - OK
InOut() START
DSR is OFF
Are you certain that you’re using the new auth code, from your new project, and that there aren’t any incorrect/illegal characters that are caused by copying/pasting it incorrectly?
Thanks for the information. I did look at the termite program but is a little complicated for me. This was my first project with Blynk and it went without any issues. But in only worked for one day, when it went offline I could not get it back online or any new projects. Just seems strange to me for such a simple project. My goal was to connect with WiFi. I ordered a SparkFun WiFi Shield - ESP8266 and WiFi Module - ESP8266. Hopefully I have better luck WiFi. Thanks for your help.
Good news! Online since 11;35 AM Aug 6. Turned off firewall and connected LAN cable from router to laptop and then I was able to get project online. Then I turned firewall back on and removed LAN cable, power cycled laptop and now PC is connected by WiFi the way it was originally and I can still get the project online. Not sure what the root cause was but just happy it works. Thanks again for your help.
@PeteKnight
The firewall usually not only looks at ports but also grants access for certain programs.
Therefore the fact that the browser can access a webserver on port 80 does not imply that
any other program has this right as well …
