Hey all,
Looking for some guidance with a school project. There are two issues I need help with.
First, I need the sensor values from preSensorPin and postSensorPin values “smoothed” out in some fashion. Currently while testing the prototype, while water is not flowing through the system, I am seeing as much a 1 psi delta between pre and post psi, when really the psi delta should be close to 0 psi.
Second, with the blynk app, is there a way to send the current filterStatus to the app project screen on blynk (filter ok, order filter, change filter)? I have been able to operate the flush out valve and see pre and post psi values, but for a more user friendly interface, I would to just see the filter status.
Thanks in advance for any help, and if any of you have some time to explain what needs to happen, I can vemno money.
REV_5
Automated Water Filter System
2/8/19
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
enum FilterStatus {FilterOk, OrderFilter, ChangeFilter};
float prePsi; //declaring pre-filter sensor psi
float postPsi; //declaring post-filter sensor psi
byte preSensorPin = A3; //assigning pre-filter sensor to A3
byte postSensorPin = A1; //assigning p-filter sensor to A1
const byte yellowLEDPin = 2; //assigning pin number to yellow LED
const byte redLEDPin = 5; //assigning pin number to red LED
const byte flushValveSolenoidPin = 7; //assigning pin number to flush valve
const byte buttonPin = A2; //assigning a pin number to button
const byte hotPin = 6; //assigning a pin to hot wire
float redLEDThresholdPsi = 1.5; //assigning a pressure threshold for red LED to illuminate
float yellowLEDThresholdPsi = 1.25; //assigning a pressure threshold for yellow LED to illuminate
int flushValveThresholdPsi = 55; //assinging a pressure threshold for flush out valve to open
const uint32_t flushValveDelay = 5000UL; //assigning a delay for flush out valve
const uint32_t minFlushInterval = 2UL * 60UL * 1000UL; // Minimum time between flushes, however invoked
uint32_t flushValveOnAtMs = 0 ; // flush timer
bool inFlush = false ; // flush timer status
FilterStatus FilterCondition = FilterOk;
char ssid[] = "REMOVED";
char pass[] = "REMOVED";
//Project Token from Blynk
char auth[] = "545a7ce537d04d53a3d6922bef1e47c3";
Serial.println("\nStarting...");
pinMode(preSensorPin, INPUT); //sets pre-filter sensor value as input
pinMode(postSensorPin, INPUT); //sets post-filter sensor value as input
pinMode(yellowLEDPin, OUTPUT);
pinMode(redLEDPin, OUTPUT);
pinMode(flushValveSolenoidPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(hotPin, OUTPUT);
digitalWrite(hotPin, HIGH);
if (!inFlush)
ManageManualFlush();
prePsi = GetPsi(preSensorPin);
Serial.print("Pre-filter psi: ");
Serial.print(prePsi);
postPsi = GetPsi(postSensorPin);
Serial.print(" Post-filter psi: ");
Serial.println(postPsi);
Serial.println("Pressure Drop");
Serial.println(prePsi - postPsi);
delay(2000); //delay in between reads for stability
ManageFlush();
CheckFilter();
ManageFilterLeds();
float GetPsi(byte AnalogPin)
int SensorValue = analogRead(AnalogPin); //read raw reading from sensor
float Voltage = (5.0 / 1023.0) * SensorValue; //calculating voltage from raw reading
return (Voltage - 0.5) * (100.0) / (4.5 - 0.5); //calculating psi from voltage
void CheckFilter() // Filter condition state machine
// All we can do is go from OK to order or from Order to change
switch (FilterCondition)
case FilterOk:
if (prePsi - postPsi > yellowLEDThresholdPsi) // if the pressure drop is greater than Order threshold
Serial.println("Order filter");
FilterCondition = OrderFilter;
break;
case OrderFilter:
if (prePsi - postPsi > redLEDThresholdPsi) //if the pressure drop is greater than replace threshold
Serial.println("Change filter");
FilterCondition = ChangeFilter;
break;
case ChangeFilter: // Once we're in this state, only a reset will change it.
break;
void ManageFilterLeds()
case FilterOk:
Serial.println("Leds off - filter ok");
digitalWrite(redLEDPin, LOW);
digitalWrite(yellowLEDPin, LOW);
break;
case OrderFilter:
Serial.println("Show yellow - order filter");
digitalWrite(yellowLEDPin, HIGH);
break;
case ChangeFilter:
Serial.println("Show red - replace filter");
digitalWrite(redLEDPin, HIGH);
break;
void ManageManualFlush()
if (digitalRead(buttonPin) == LOW && !inFlush)
Serial.println(F("Manual flush"));
StartFlush();
void ManageFlush()
if ( inFlush && millis() - flushValveOnAtMs >= flushValveDelay ) // if flush timer expired stop flushing
StopFlush();
if (!inFlush && prePsi < flushValveThresholdPsi) // if the psi is lower than threshold see if it's time for an auto flush
FlushIfWeMay();
void StartFlush()
inFlush = true;
digitalWrite(flushValveSolenoidPin, HIGH); // open flush out valve
flushValveOnAtMs = millis(); // start flush timer
Serial.println(F("Start flush timer"));
void StopFlush()
digitalWrite(flushValveSolenoidPin, LOW); //close flush out valve
inFlush = false;
Serial.println(F("Stop flush timer"));
void FlushIfWeMay() // Flush if enough time has passed since the last one or if we don't know when the last one was
if ((millis() - flushValveOnAtMs > minFlushInterval) || flushValveOnAtMs == 0) // Honour an initial request for flush - who knows when we did it last
Serial.println(F("Auto flush"));
StartFlush();
Serial.print(F("Flush request denied - did one too recently. Next opportunity in: "));
Serial.print((minFlushInterval - (millis() - flushValveOnAtMs)) / 1000UL);
Serial.println(F(" seconds."));
