Arduino project is offline error. Cant see any values in the app
Im using an arduino uno with an esp8266 wifi module.
I need to see the current values of temperature and humidity which are sensed by dht11 sensor
Im getting error saying that my project is offline. Whereas my serial monitor says that Im connected to wifi
Here is my code:
#include <ESP8266_Lib.h>
#include <DHT.h>
char auth[] = "74a2XXXXXXXXXXXXXXXc5bccdeb";
char ssid[] = "Ninad";
char pass[] = "90XXXXXX02";
//#define EspSerial Serial
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
#define DHTPIN 7          // What digital pin we're connected to
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  // Set ESP8266 baud rate
  Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
  dht.begin();
As per the directions you erased in order to post this :wink: … I fixed your posted code’s formatting…
Blynk - FTFC
Now search this site for keywords like ESP-01, UNO, etc. and read through them all as you are probably missing a step and your issue is answered already in another topic.
You also have this command repeated…
I commented the blynk.begin() in the second line. The problem still exists with the same error.
I tried changing the rx and the tx pins
Search this forum for keywords like UNO & ESP-01 lots of reading, but all the troubleshooting ideas and solutions are already there.
