Add details : I’m trying to make an electric gate to be an IOT by using sim800L, arduino nano, RF transmitter. it has its function to be controlled by Blynk, when in Blynk dashboard the button V0 is On=(close), every 30 mins it will send signal to open just to make sure to be close. i add V1 as a terminal widget, i add V2 as a storage of the current state of the gate to confirm its action whether to close the gate or open it. when i try to connect to sgp1.blynk.cloud is connected but it returns “Cmd error” from blynk debug in serial monitor. I need help ASAP. here is the serial monitor prints:
01:09:23.073 -> [402527] Connecting to sgp1.blynk.cloud:80
01:09:24.559 -> [403990] <[1D|00|01|00|20]Cm*****************************G
01:09:25.502 -> [404952] >[00|00|01|00|C8]
01:09:25.534 -> [404953] Ready (ping: 859ms).
01:09:25.566 -> [404953] Free RAM: 720
01:09:25.599 -> [405020] <[11|00|02|00|9A]mcu[00]0.0.0[00]fw-type[00]TMPL6_****m[00]build[00]Mar[20|20]1[20]2024[20]01:02:21[00]blynk[00]1.3.2[00]h-beat[00]60[00]buff-in[00]256[00]dev[00]Arduino[20]Nano[00]cpu[00]ATmega328P[00]con[00]SIM800[00]tmpl[00]TMPL6_l***m
01:09:27.001 -> [406431] Cmd error
• Hardware model + communication type: arduino nano, gprs sim800L
• Smartphone OS (iOS 17.3.1)
• Blynk server region ![]()
• Blynk Library version : 1.3.2
• Post your serial monitor output when experiencing some issues
Here is my code I create :
#define BLYNK_TEMPLATE_ID "TMPxxxxxx"
#define BLYNK_TEMPLATE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#define BLYNK_DEBUG
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
#include <RCSwitch.h> //rf library
char apn[] = "gprs";
char user[] = "gprs";
char pass[] = "gprs";
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(3,2); // RX, TX
TinyGsm modem(SerialAT);
RCSwitch RfOutput = RCSwitch();
int stateInMemory=0; // the current reading from the input pin
int qtyResend = 0; //counting how many it resends
int SigQual;
// This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
//get data stored in virtual pin V0 from server
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V2);
// restoring counter from server
BLYNK_WRITE(V0)
//lastOutputState = EEPROM.read(0);
if(param.asInt()==1 && stateInMemory==0) //v0 is 1 memory is 0
//send rf signal on
sendRfComp();
//saving
stateInMemory = 1; //invert
Blynk.virtualWrite(V2, stateInMemory);
//delay(40);
Serial.println("1 on");
Blynk.virtualWrite(V1, "\n 1 on");
//Blynk.logEvent("on_jbr_sent");
else if(param.asInt()==0 && stateInMemory==1) //v0 is 0 memory is 1
// Binary code - rf off
RfOutput.send("24 digit boolean"); //send rf signal off
//Serial.println("off A1");
//delay(40);
//Serial.println("off B1");
//delay(40);
//Serial.println("off C1new");
stateInMemory = 0; //invert
qtyResend = 0; //reset resendcounter
//delay(50);
Serial.println("1 off");
Blynk.virtualWrite(V1, "\n 1 off ");
//Blynk.logEvent("off_jbr_sent");
Blynk.virtualWrite(V1, "Prob dtcted"); //debug
Serial.print("memory is ");
Serial.println(stateInMemory);
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("ck") == param.asStr()) {
compSig();
Blynk.virtualWrite(V1, "\n resnd alr ");
Blynk.virtualWrite(V1, qtyResend);
BLYNK_WRITE(V2)
//restoring int value
stateInMemory = param.asInt();
void increment() {
if(stateInMemory==1)
sendRfComp();
qtyResend++;
// Set GSM module baud rate
SerialAT.begin(9600);
delay(3000);
Serial.println("Init mdm");
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Blynk.begin(BLYNK_AUTH_TOKEN, modem, apn, user, pass,"sgp1.blynk.cloud");
timer.setInterval(900000L, increment);
RfOutput.enableTransmit(10); //to tx pin of rf transmitter
RfOutput.setPulseLength(350);
RfOutput.setProtocol(1);
RfOutput.setRepeatTransmit(2);
compSig();
void compSig() {
Blynk.virtualWrite(V1, "\n sgnl qty ");
SigQual = modem.getSignalQuality();
Blynk.virtualWrite(V1, SigQual);
void sendRfComp(){
//send rf signal on
// Binary code - rf on
//Serial.println("on A1");
//delay(40);
//Serial.println("on B1");
//delay(40);
//Serial.println("on C1new");
