I am trying to configure an Arduino Nano RP2040 Connect via WiFi as a device
I am using arduino IDE to program the device.
Also I installed the latest blynk library 1.2.0 and Blynk_WifiNINA_WM 1.1.2
None of the examples are working
Files > Examples > Blynk → Blynk_Wifi
Files > Examples > Blynk_WifiNINA_WM
OPTION 1: Files > Examples > Blynk_WifiNINA_WM → RP2040_WifiNINA_WM
Giving the following compile errors:
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:166:12: error: 'Timer' does not name a type; did you mean 'time'?
static Timer blynk_millis_timer;
time
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:167:12: error: 'Ticker' does not name a type; did you mean 'Socket'?
static Ticker blynk_waker;
Socket
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp: In function 'void BlynkSystemInit()':
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:177:9: error: 'blynk_waker' was not declared in this scope
blynk_waker.attach(&blynk_wake, 2.0);
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:177:9: note: suggested alternative: 'blynk_wake'
blynk_wake
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:178:9: error: 'blynk_millis_timer' was not declared in this scope
blynk_millis_timer.start();
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:178:9: note: suggested alternative: 'millis_time_t'
millis_time_t
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp: In function 'void BlynkDelay(millis_time_t)':
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:183:9: error: 'wait_ms' was not declared in this scope
wait_ms(ms);
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:183:9: note: suggested alternative: 'wait_ns'
wait_ms(ms);
wait_ns
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp: In function 'millis_time_t BlynkMillis()':
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:188:16: error: 'blynk_millis_timer' was not declared in this scope
return blynk_millis_timer.read_ms();
C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk\src\utility\BlynkDebug.cpp:188:16: note: suggested alternative: 'millis_time_t'
millis_time_t
Bibliotheek Blynk_WiFiNINA_WM op versie 1.1.2 in map: C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk_WiFiNINA_WM wordt gebruikt
Bibliotheek WiFiNINA_Generic op versie 1.8.15-1 in map: C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\WiFiNINA_Generic wordt gebruikt
Bibliotheek Blynk op versie 1.2.0 in map: C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Blynk wordt gebruikt
Bibliotheek WiFiWebServer op versie 1.10.1 in map: C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\WiFiWebServer wordt gebruikt
Bibliotheek Functional-Vlpp op versie 1.0.2 in map: C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\Functional-Vlpp wordt gebruikt
Bibliotheek DoubleResetDetector_Generic op versie 1.8.1 in map: C:\Users\waalk.VSE\OneDrive\HomeProject\Arduino\libraries\DoubleResetDetector_Generic wordt gebruikt
Bibliotheek SPI in map: C:\Users\waalk.VSE\Documents\ArduinoData\packages\arduino\hardware\mbed_nano\3.5.4\libraries\SPI (legacy) wordt gebruikt
exit status 1
Fout bij het compileren voor board Arduino Nano RP2040 Connect
OPTION 2: Files > Examples > Blynk → Blynk_Wifi → Arduino_MKR1010
Giving the same compile errors:
